Name my rear
Discussion in 'The Hokey Ass Message Board' started by Boones, Nov 20, 2009.
  1. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    The 31 PU I got came with a rearend that I can not identify. its a 5x5.5 pattern matching the front 40 ford drums.. At first I thought Olds, but those I believe are 5x5. some folks have said early 8 3/4 (but some say those would have a pinion snubber..)
  2. The front shot of it looks alot like a 55-6 Ford rear end, could be Merc or Lincoln.. maybe a little earlier.
    then re-drilled axles for the 5.5 pattern.
  3. squirrel
    the casting number looks like 50s ford also
  4. pre 57' ford truck would be dana. axles might be re-drilled. pull brake drum and post pic of rear brakes, post wheel cyl. casting #'s
  5. George G
    George G
  6. Ruiner
    Ruiner
    Name your rear? I'll call it "Super Happy Fun Land"...do you charge admission, or can I just go on a ride?
  7. Southfork
    Southfork
    It's a very nice looking rear end, whatever it is --- or at least it would be if it didn't have that bracket bubblegum welded on the top of it. I also wonder what the heck it is, cause I know where there's one like it at a wrecking yard.
  8. Cruiser
    Cruiser
    Boones - Looks like a 9" Ford rear end about 1957 without the two dimples on it. Station wagon measured out a 57" Backing plate to backing plate if longer a regular passing car.
    CRUISER :cool:
  9. Left Turn
    Left Turn
    from Omaha, NE
    I'd call your rear the Turd Cutter..... oh wait...
    Looks like 50's ford... I've got one from a '55 or so ford that looks the same... I think... It's to dark out..
  10. squirrel
    nope, this one has a round pumpkin, the 9" is oval. Among other things.
  11. smarg
    smarg
    This could be an 8in. Ford just a thought?????
  12. squirrel
    nope...8" is also oval, and also has a separate pinion bearing support that unbolts.
  13. czuch
    czuch
    from vail az
    I have one outta 61 galaxie that had the hipo 390 innit.
    They look pretty much the same.
    Reeeeaaaaly should not have parted that one out.
  14. punkroder
    punkroder
    from socal
    looks like olds or pontiac to me. But the ones ive owned were all 5on5
  15. hotrod-Linkin
    hotrod-Linkin
  16. moses
    moses
    metal..... lol..jeffrey
  17. butch27
    butch27
  18. gimpyshotrods
    gimpyshotrods
    That looks like the right alpha-numeric pattern for a Ford part number, but I can't make it into anything.
    Um, planning on doing anything with those ladder bars? I believe that you are in danger.
  19. Boones
    Boones
    from Kent, Wa
    gimpy I am planning to redo the whole rear set up (and some frame work), just trying to figure out if I should use this rear or not I like that it is 5x5.5 so I can run early wires or 40 ford rims etc.. .. I tried running those numbes on Google with no luck
    I have an 8" as an alternative but its 5x4.5 (and I hate having mis matched front to rear patterns). The current set up was powering a flattie, I am going to be running a mild sbc.. I am going with ladder bars and quarter elipticals I think...
    is there any foriegn PU rears that had a 5x5.5 rear
  20. dalesnyder
    dalesnyder
  21. squirrel
    the pumkin looks way too big to be a toyopet? and that flange...
  22. gimpyshotrods
    gimpyshotrods
    Excellent. I am never wanting to be critical of anyone else, or their ride, but I do worry. I don't want any of you guys dyin' on me. I NEED you knowledge and wisdom.
    If there is enough meat in the 8" axle flanges, you can get them re-drilled to 5 on 5-1/2". You'll have to pull a drum and measure the size of the flange. In any case, I would recommend the 8" over an "unknown or odd-ball" rear end (or a *gasp* Japanese or Korean one).
    That does look somewhat Toyota or Suzuki, but it does not match any that I personally know of. Toyota would not have been 5 on 5-1/2" either. I'd pull a drum and look for a re-drill on that one.
    Daihatsu, Kia, Mistsubisi, and Suzuki have all used 5 in 5-1/2" in recent history. Suzuki Sammuri's had a removable 3rd member too, and that bolt pattern, and were about that wide. None that I remember had a round face like that.
    Oh, and I now found this:[​IMG]
    Its a Olds, and the backing plates look really close, but the center is way different.
  23. flamedabone
    flamedabone
    Dude...I was thinking about your rear end today...:rolleyes:
    I was in the parking lot of my local quickiemart and saw an 80's ish Toyota truck. The rear end looked exactly like yours...The only diffrence was the one I saw had a drain plug on the bottom. Does yours???
    PS. The Yoda had 5 on 5.5 also. Had those ugly ass Ford pick up rims on it...
    But..I have been wrong before..
    See ya, -Abone.
  24. madpole
    madpole
    sure looks like a olds/pontiac to me.
  25. dalesnyder
    dalesnyder
  26. squirrel
    the early Land Cruiser was a copy of the Chevy 4x4 drivetrain from the 50s-early 60s.
  27. Brickster
    Brickster
    the pinion yoke looks like the stock one from my 50 ford sedan.
  28. toyota truck was 4 on 4.5"bc 4wd toyota was 6 lug. cant really read those numbers post them again.
  29. Boones
    Boones
    from Kent, Wa
    did another review (can't pull the rims right now due how it is stored)
    The letters on the center section look like WAD4023A
    There are two drain holes on the rear, one on the pumkin and the other (alittle smaller) on the housing at the bottom (like FlamedAbone mentioned). there are 10 bolts holding the pumpkin in. Also the rear smooth section measure about 8.5" wide
    I am now leaning towards a Toyota land cruiser rear as it has similar looks to what dalesnyder posted (anyone own a land cruiser...
  30. i'm going with a samurai with the welds smoothed and different yoke.
    ok i think i'm wrong, samurai has 8 bolts i think (pattern looks different).
