Nailhead Oil Pumps
Discussion in 'The Hokey Ass Message Board' started by slappy1eye, Oct 28, 2013.
  1. slappy1eye
    slappy1eye
    I've searched around and it seems no one can answer the question, what is the difference between the 59-61 & 62-66 401 oil pumps? I know there's a difference to the side filter housing 59-60 is different than 61-66. But how does that effect the pump? What are you guys using as a Hi-Volume pump in a 59-60 401?
  2. slappy1eye
    slappy1eye
    As per Russell Martin - The Buick Guru @nailheadbuick.com - "The mounting holes are in a different place, the 62 was designed for a center sump pan, different holes in the block. The 59-61 oil pump is the best Buick pump".
