Naapco 4x4 59 Apache
Discussion in 'The Antiquated' started by Topherchris1, Oct 11, 2019.
  1. Topherchris1
    Topherchris1
    I’m wondering if anyone knows if a Naapco kit from a 1960 suburban will bolt up to a 59 Apache 32 with 3 speed muncie
  2. *JW*
    *JW*
    I would try to contact Jeff Bradshaw in Medford Oregon. He has a YouTube channel called ElderlyIron and seems to have lot of experience with those old Napco 4x4s.
    tractorguy and 1morecarIpromise! like this.
  3. deathrowdave
    deathrowdave
    from NKy
    I’m beating it’s a direct swap . Frame width the same ? If so it can be made to warm fairly easily
  4. s55mercury66
    s55mercury66
    from SW Wyoming
    The transfer case is divorced, so with some driveshaft fabbing, that will work, and the front axle might. Are you certain the 1960 parts are Napco? GM had gone to their own parts and design for the factory built 4wd's in 1960, and none of that stuff is Napco. I have a '59 line built Napco here if you want some pics of how all that stuff mounts and what it looks like.
    tractorguy likes this.
