mystery car update
Discussion in 'The Hokey Ass Message Board' started by GEGE, Jan 24, 2012.
  1. 32 hudson
    32 hudson
    Nice Bucket. Just the right stance and I like the whites. What size and brand of tires ?
  2. R Pope
    R Pope
    How many times have you heard, "is that a kit car?" Grrrrr.......
  3. swissmike
    swissmike
    Very nice. Not too sure about the cycle tires up front, though.
    There have been 3 very nice T-buckets on the HAMB lately that I noticed. Is there a new fad in the making...?
  4. GassersGarage
    GassersGarage
    I'm usually not a fan of T-buckets, but yours rocks.
  5. Molonewolf
    Molonewolf
    Love the bomb gas tank!
  6. 53Hattie
    53Hattie
    Ditto what KoolKat-57 said! So refreshing to see a bucket that looks "real", ...'cause it IS of course! The wheel/tire combo is bitchen, no way wonky! Sweet!
  7. 53Hattie
    53Hattie
    Gotta cast another vote in favor of T&R and standard carpet instead diamond & fuzz, purple is fine however...
  8. 42hotrod
    42hotrod
    from S.E. Idaho
    Yup Diamond was really 70's even into early 80's. That sharp looking little bucket needs some tuck n roll and please no ugly ass shaggy carpet!!!
  9. hot_rod_bones
    hot_rod_bones
    from topeka, ks
    love the fuel tank, but have always disliked the tall windshield.
    nice ride
  10. firingorder1
    firingorder1
    If you do the diamond tuft people will look at you car and wonder how long it took you to build it. Mid 50s build. Didn't get around to upholstering it until the early 70s. Its gotta be T & R!!
  11. gimpyshotrods
    gimpyshotrods
    Wonky is British slang. Generally, it means unattractive.
    I like them, though.:D Good job. Nice ride!
  12. Atwater Mike
    Atwater Mike
    Gorgeous '37 tube axle...but do you DARE show your a$$ around Pearl with that bomb?
    Sorry, old enough to remember, young enough to speak up.
  13. Love the T ...The axle is IT! Makes me want to do a Lightening Bug clone
  14. No_Respect
    No_Respect
    from So-Cal
    Wow awesome T any more pics or updates? I wanna see the shag
  15. KustomCars
    KustomCars
    from Minnesota
    That is Sweet !
  16. Kramer
    Kramer
    Nice T, similar to the look I'm wanting in mine. Love the gas tank. Would love to see more pictures of it. I'm not against stealing ideas.
  17. Kramer
    Kramer
    Never mind. I found your other threads. Loving it even more now.
  18. GEGE
    GEGE
    here is naked ladies on fur
  19. Nice Bucket. Don't take off the whitewalls they look good. I remember when nobody ran blackwalls. That gas tank is a cool item. Best wishs from the Great White North.
  20. LSR 2909
    LSR 2909
    from Colorado
    Nice ride.
    The only mystery I see is purple fur carpet? What did that nice T do to you?
  21. GEGE
    GEGE
    black tuck and roll is it.
    White top and bed cover.
    purple fuzz carpet.
    Should be done next week and should be at the LA Roadster show.
    Already back to the old project "Surf Angel".
    Finally!
  22. Jim Bouchard
    Jim Bouchard
    Just saw the car at the upholstry shop and recognized it from the HAMB and now
    it is the first post. Too COOL. Its looking good!
  23. pride63
    pride63
    wonky is actually british for uneven not unattractive
  24. Sumfuncomet
    Sumfuncomet
    What makes that look so cool is that bed.....very nice looking piece of work!
  25. Colville
    Colville
    Good job... That thing looks great!
  26. Tony
    Tony
    Same here. Not often i see one i like. Yours i do, a lot!
    Very cool!
    Tony
  27. Jon Dunchack
    Jon Dunchack
    Great car, love that '37 front axle, as noted earlier - it really makes the car and continues the heritage back to Bukowski and Ivo.. Can you please tell us the work that was involved in placing the spring behind the axle? Thank you.
  28. Kool bucket & nice touch with the oil can.
  29. frankenstein1948
    frankenstein1948
    Wow! Not usually a big fan of T buckets but you nailed it with the look on this one.
    Very cool!
  30. GEGE
    GEGE
    Jon, answer your question, you can see this in the second set of pics, on the split rods i drilled a hole, i welded a sleeve into it for the spring perch's, i shortened the perches and rethreaded to correct length, installed some left over springer pike nuts from an old roth front end for looks, of course i needed to coral a correct length spring.
    When installing all on the car i loosen the pike nuts so perch is out slightly, install the spring and bolt it to the frame, then drop the car and the spring is able to find the perfect alignment to the radius rod because the perch can rotate in the sleeve, then i tighten it and wola, perfect alignment, no bind.
    the frame spring mount is raised to get the car down and it has a cover with hidden screws so you do not see the bolts and it blends in and looks like the cover is part of the frame. more pics to come as the interior and top will be done next week.
