Projects My Willys Gas Coupe build
Discussion in 'The Hokey Ass Message Board' started by langy, Mar 20, 2011.
  1. n847
    n847
    I always wondered how they ran the fuel pressure gage inside the cabin like that! I love that you can show your work through the reflection in your polished firewall!
  2. Jimmy Tee
    Jimmy Tee
    I haven't looked through your thread in a while Steve. I just went through the last 6 pages. Simply brilliant mate. I think we all appreciate the effort and detail you put into your updates.
  3. langy
    langy
    Yeah you get fuel up to the isolator then the line from the isolator to the gauge is filled with 50% antifreeze & 50% water, its a bugger of a job to fill and get the air out :(
  4. 1954satan
    1954satan
    "aint that the truth" but well worth the effort to avoid any fuel spraying over everything in the cockpit in the event of a leak. just as an experiment when setting mine up I ran a temporary gauge both sides of the isolator to check the accuracy and it was dead on correct. and those axles you did for me Steve are perfect thanks again.:cool:
    and dont forget if you make the hot rot drags we want video,, pics,, ect.
  5. langy
    langy
    Your welcome Ray.
  6. langy
    langy
    Woo Hoo my heads arrived today exactly on time, not bad at all when you consider they were still in SoCal on monday afternoon !!! now the first race begins !!! it will be tight timewise but hope to get it to HRD's
    They are really nice and I had hoped to get them painted this afternoon but as usual its pi$$ing down with rain !!!
  7. captain scarlet
    captain scarlet
    from Detroit
  8. langy
    langy
    feels like i've been waiting that long mate !!!
  9. Skimmer
    Skimmer
    Right Steve leave the computer alone and get that Willys running......
  10. langy
    langy
    Put the bank holiday monday to good use and got my heads painted, my Titan head gaskets should arrive tomorrow so hopefully will get them bolted in place.
    Gold flake over a black epoxy primer base.
  11. I can't wait to see this engine all put together!!
  12. farmer12
    farmer12
    Nice job on flaking the heads Steve! This is going to be one special looking engine when it's all bolted together. Next time I'm in London, I'll be over to check it out! Awesome.
  13. langy
    langy
    Me neither mate, it seems to be taking ages :(
  14. langy
    langy
    Thanks Eric, your always welcome mate
  15. langy
    langy
    Somebody asked why don't I just nail it together quick !!! Well everything needs to be put together and clearances checked, Last night this was typified by a clearance problem on my roller rockers, 3 of them are scraping the valve spring retainer, I think I have the problem solved by installing a spacer under the rocker shaft supports and use a slightly longer pushrod or buzzing a bit off the rockers, I've emailed the supplier to see what they suggest.
    Had a slight accident last night with one of the roller lifters, It won't hold me up though as there is already a replacement due here on saturday.
    I assembled the motor with stock gaskets to check piston to valve clearances and everything was fine and will put it all back together tomorrow night for the last time.
    Here is how its looking put together, still not made my mind up what to do with the valve covers but they can stay natural until I do.
  16. BigAl1961
    BigAl1961
    I'll miss seeing this build on the NEW updated HAMB
  17. It would probably make the cut if the picture of the rocker arms and valve covers weren't here...Can't tell it's made of 'glass when it's doing 120.
  18. rottenleonard
    rottenleonard
    How hard would it be to modify some 390 cadillac script valve covers to fit?
  19. KFC
    KFC
    from UK
  20. brian55lvr
    brian55lvr
    from ma
    thanks for the info richard--- whew
    ryan quote
    they won't be deleting the old stuff... Just closing it.
  21. cederholm
    cederholm
    You craftsmanship and attention to detail leave me speechless!! BRAVO!!
    ~ Carl
  22. langy
    langy
    Well my Head gaskets turned up bang on time so the top end was stripped off for final assembly, all clearances were fine and everything worked like it should so it can now go back together for the last time
    I thought i would post a pic of the SCE Titan copper gaskets, they are really clever bits of kit as they are fitted with O rings which save a lot of expensive machine work on the block.
  23. langy
    langy
    Yeah I just found out today about the changes :(
  24. langy
    langy
    I'm working on it but its not a priority at the moment.
  25. langy
    langy
    So Brian its sounds like my project won't be welcome but they will leave the thread here for info, correct ???
  26. its a glass body. maybe the caddy engine. the hammer is comin down startin the 1st.
  27. langy
    langy
  28. 2racer
    2racer
    I think your work is outstanding and you are an asset to this forum.
  29. its possible. ryan and his crew are gona clean house a little bit. read this for more info. then read all the comments, he mentions more in those. plus more is coming soon. http://www.jalopyjournal.com/?p=20204
    langy i love this build, if you dont continue it here i look forward to see the completion on the forum you linked. you sir are truly a master at this stuff.
