My new military french flathead will be converted to a Hot Rod engine
Discussion in 'The Hokey Ass Message Board' started by HOTRODSWE, Oct 18, 2010.
  1. ytt49
    ytt49
    from socal
    looking pretty good.
  2. HD74
    HD74
    I'm running FFH in my 51 pick-up and very happy with it. One suggestion is to remove the bosses on the back of the block. Should help with firewall clearance.
  3. doctorZ
    doctorZ
    [​IMG]we got you beat!
  4. HD74
    HD74
    Any of them with the aluminum oil pans?
  5. ventilo
    ventilo
    all of the 3.9 litre French Flatheads pictured should have the alloy oil pans with rear sump
    but not all of them have the ugly bosses casted at the rear, the earlier ones came without
    I took some measurements of the critical aeras - and yes the French invented the metric system ;)
  6. doctorZ
    doctorZ
    not those, but we have plenty if you need one.
  7. kerker
    kerker
    Do you still have the pan/?
    Dick
  8. HOTRODSWE
    HOTRODSWE
    Now, finally I,m ready to put up some photos and tech around the build.
    The extra material for the gov. boss, need to be machined, to get clearance on firewall
    Done, need to do some grinding and plug the holes
    There is no holes for the scatter bars
    Need to be drilled if you are going to use bars, I need it, as I will explain later
  9. HOTRODSWE
    HOTRODSWE
    The bottom rail, se marking, need to be grinded about 1/4" to get oil back in pan, as the 59AB oil pan breather need to be plugged
  10. Jalopy Banger
    Jalopy Banger
    from Sweden
  11. HD74
    HD74
    Your making real good progress. Here's the backend of mine before I put it in the truck.
  12. Cool roadster and keep the updates coming on what you have todo to get the motor into your hot rod.
  13. what do you do to the holes in the area that you machined? tap them and plug them?
  14. HOTRODSWE
    HOTRODSWE
    Some of them I did tap and on some I did put a slight over dm plug in
  15. HOTRODSWE
    HOTRODSWE
    Did some mock up
    To try to get the fanbelt issue sorted out
  16. HOTRODSWE
    HOTRODSWE
    The solution I went for was to use one belt from crank to generator, and then another one from generator to pumps. To get that working with only one adjustment (generator) I made a special pulley with outer groove seperated in two halfs, so that I could shims them to get belt tension. I will get some photo of it later.
  17. looking good!!
  18. HOTRODSWE
    HOTRODSWE
    I painted the block in some early style ford green
    And did plug the two holes for water passage, so that I could use 59AB styled heads
  19. did you clear coat that? it does look good!
  20. HOTRODSWE
    HOTRODSWE
    No clear, just standard 2k car paint
  21. plym_46
    plym_46
    from central NY
    Nice to see those old MOPAR motor getting used. Seems Mopar built them longer than ford did..............
    Built by Simca under license when Simca was owned by Chrysler.
  22. ventilo
    ventilo
    Can you please explain in more detail?
    I might have that issue on my French Flatties as well. I'm running a French block with it's original alloy oilpan but an early 21-stud intake and the fuel pump stand breather.
    What exactly needs to be modified to get him breathing right?
    BTW: I'm running G29T style water pumps, allowing for a single fan belt together with the dual French pulley and an 8BA style PowerGen.
  23. HOTRODSWE
    HOTRODSWE
    I,m not familiar with the design of the alloy oilpan, but if it don,t have any breather, you will need a PCV valve from what I understand. I have mounted one in my intake (I will show some pictures later) and it seams to work for me.
    The reason for grinding in the block is that the french block have the oil return here (from valve area to oil pan) and with no grinding the oil return will be blocked by the pan.
  24. ventilo
    ventilo
    tack så mycket - so with my French alloy rear sump pan I should be fine and this modification is only req'd if using a steel pan.
  25. HOTRODSWE
    HOTRODSWE
    You need to check that the oil return hole has free conection to the oil pan, either thru oil pan or grinding in block
  26. flatheadz-forever
    flatheadz-forever
    from new jersey
    Where could I find a french flathead I need one for my build? any help guys?
  27. ibarodder
    ibarodder
    Boy I'd like to get my hands on that roadster, got any more pictures of it ?
  28. Mart
    Mart
    If the aluminum pan came with the French engine it is shaped to return the oil correctly. Problem happens when you fit a 59A Ford pan.
    I also have a French block with G29T pumps, works very well. The pumps are nicely made and rebuildable I got parts from Flatordead in Germany.
    I am running early style manifold and rigged a PCV valve hidden in the valley.
    Mart.
  29. no55mad
    no55mad
    Old Ford in Campbell Ca has a French block in their showroom. One of the owners at SoCal Sacramento Ca has used many French blocks if you want to try and pick his brain.
  30. HOTRODSWE
    HOTRODSWE
