This video contains content from SME, who has blocked it in your country on copyright grounds. What kind of nonsense is this Ah, it's the soundtrack.... What is a YouTube SME? It means that the content owner Sony Music Entertainment (SME) is not allowing YouTube to broadcast the video in your region.
I wonder which track is causing the problem? I have used 3 tracks Rare Earth - Get Ready, Cars - Just What I Needed and Romantics - What I Like About You. Any help, so maybe I could change out the problematic track.
Ive reciently started watching a lot of U Tube video. Since ive got a large screen TV to watch it on. Myself I don't like background music. I don't hear so good and its annoying to me. So if something has background music I turn off the sound. And I close caption it. If there isn't close Caption and it has music or excessive background noise I don't watch it.
Two are just part tracks but one looks like I may have pretty much run the full track, so this maybe the glitch!!! Tricky business...
It all played for me. Russ, I should have sent you a picture of my 346 with Edmunds heads and a matching dual deuce intake. Plus a Spalding flamethrower sticking up behind the carbs.
That's what I like about Chew! Sounds like a 'billy with a plug in his lower lip... Say, Russ...What kind of body is that? Swoopy frame scratch built, or 'pie cut with many welds'? Totally compliments that Flat Caddy...Like how you went 'conservative' with the exhaust. Stock manifolds still ceramic coated?
I found the solution and watched the video First you copy the video URL by right clicking on the video. Then you go here https://www.unblockyoutube.co/ You enter the URL and click go to site. And watch the video
Rare Earth Track released 1969, The Cars Track released 1978 and The Romantics in 1980, so I am in the 50 years thing with all three, darn...
I rebuilt the engine in a 46 Cad. I tried yanking with my cherry picker. I was scared it would break with the boom bending. Got my IH 350U with a loader and needed the weight bucket on the back........still a bit scary!
I hear you buddy, I broke my shop crane trying to lift a stock Cadillac flathead engine and tranny and few years back and had always been concerned about moving my current Cadillac flathead project engine from an engine running stand into my finished chassis. In the end I decided to do it right, since I have no mechanical plant to use. So I decided to build a gantry crane into my shop roof area just for this task. Over kill I know but much more versatile than a simple lifting arrangement... I maybe wrong but I did some calculations and came up with a figure of about 1350lbs of weight between my engine and tranny when about 95% assembled. The good news is that it is in the frame now, an exercise that turned out to be uneventful, just the way I like'm.
Man! Bitchin roadster! You gained a subscriber! I'll subscribe when I get off work. I've been wanting to pick up YouTube myself, figured out I'm not the type for it. Sent from my iPhone using The H.A.M.B. mobile app
I have a book that says the motor alone and dry is 900 lbs. I stripped my 346 down as far as i could before I pulled it from my 37 sedan back in 1993 or 94. Heavy motor but in stock form it runs smooth.
They might have start the between Canada and US . cause here ,we are not allowed to see the video... but picture are kool...
I am not getting any better at this but still fun. No calls from Hollywood yet !!! Here is my next in the sequence, maybe not to every bodies taste, but then again hot rodding is showing individuality.
