Hot Rods My belly tank racer build
Discussion in 'The Hokey Ass Message Board' started by onekoolkat1950, Sep 1, 2017.
  1. 48fordnut
    48fordnut
    Thanks all for sharing.
    kenmo likes this.
  2. Does the guy in the corner on the stairs ever help, or does he just stand there?
    i420, Stogy, HelmuthBrothers and 2 others like this.
  3. onekoolkat1950
    onekoolkat1950
    Yes sir 100%
    HelmuthBrothers, Speed~On and ABONES like this.
  4. onekoolkat1950
    onekoolkat1950
    He's just looking for snacks
    Stogy, slv63, loudbang and 1 other person like this.
  5. greybeard360
    greybeard360
    Not sure about mounting the motor and trans on rubber with the rear end mounted solid.
    Sent from my Moto G Play using The H.A.M.B. mobile app
  6. onekoolkat1950
    onekoolkat1950
    Engine and trans are able to move via the torque tube coupling. This is the same way tons of tanks are done.
  7. AldeanFan
    AldeanFan
    Where to you sit? Ahead of the engine or over the driveshaft?
  8. onekoolkat1950
    onekoolkat1950
    In the front. Water tank in front of the motor then the driver
    48fordnut and loudbang like this.
  9. wheeldog57
    wheeldog57
    Been a couple weeks since your last post. . . I bet you're driving it already
    Sent from my SM-G930V using The H.A.M.B. mobile app
    Runnin shine and bct like this.
  10. Mechman_22
    Mechman_22
    from Nc
    any updates on this
  11. mike bowling
    mike bowling
    Put some "bomber art" on the nose? (Bud) Call it Sue ( Wah Sue)
    120% as usual you crazy son-of-a-gun! Lookin' PISSAH!
    Don't mean to side step YOUR post, but here's a pic of the Barillaro's bomber from a couple of years ago so the uninitiated can see which end goes first!
    loudbang and graveyardsledder like this.
  12. GordonC
    GordonC
    Mike any idea as to why the Airstream trailer in the background was up on a stand of some sort? I saw that when I was there for the races and wondered what the story was behind that.
  13. wheeldog57
    wheeldog57
  14. onekoolkat1950
    onekoolkat1950
    [​IMG][​IMG]not much to report been really busy at work and preparing the house for winter . Got the tank cut for the rear end . I am working on the front end mount at the moment.
  15. wheeldog57
    wheeldog57
    Is that approximate ride height? You'll be able to Bo Duke right in there!
  16. onekoolkat1950
    onekoolkat1950
    It should be about 4" off the ground . Actually higher then most tanks but I don't wanna get stuck in the sand.
    loudbang, wheeldog57 and mike bowling like this.
  17. adam401
    adam401
    Ray its lookin sick bro!
  18. onekoolkat1950
    onekoolkat1950
    Thanks Adam. Hope to see you soon. Gotta do a RI visit.
  19. graveyardsledder
    graveyardsledder
    I was looking through some other belly tank pictures and the tube frame that some of the guys built back then, rather than having a water tank taking up space they ran the water through the frame tubes. I think that's what I am going to do. Make a filler neck with a radiator cap. I don't think I'm going to make a build thread because I don't want to take away from anyone else's. haha!
  20. onekoolkat1950
    onekoolkat1950
    I've also seen that done on a few tanks . Really neat idea.
  21. graveyardsledder
    graveyardsledder
    Also are you gonna make the clutch lever/pedal hydraulic or cable driven for the side shift?
  22. onekoolkat1950
    onekoolkat1950
    The plan is mechanical linkage but that can always change lol.
    graveyardsledder and loudbang like this.
  23. rusty rocket
    rusty rocket
    As always very Kool stuff going on here Ray. Did I miss it, are you going to have a canopy or open air?
  24. onekoolkat1950
    onekoolkat1950
    Planning on a full canopy
    loudbang and Stogy like this.
  25. woodbutcher
    woodbutcher
    :D You sir,are fixing to have a bunch of fun.Wishing you the best.
    Good luck.Have fun.Be safe.
    Leo
    loudbang and onekoolkat1950 like this.
  26. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Digging the progress!!! You’re a lot further along than I’ll ever be.... keep up the great pace.
  27. cederholm
    cederholm
  28. onekoolkat1950
    onekoolkat1950
    [​IMG][​IMG][​IMG]hacked up a model T crossmember and finally got the car up on 4 wheels. Decided to ditch the wavy axle idea for this project . It just weighs too much and at some point I plan to cover the front axle with a fairing. I think I'll use it in a dirt track T build in the future......
  29. Stogy
    Stogy
  30. onekoolkat1950
    onekoolkat1950
    Thanks Stogy! That car is incredible!
    jsprcn, loudbang and Stogy like this.
