Projects My 51 chevy :)
Discussion in 'The Hokey Ass Message Board' started by RICKY~RICARDO, Jan 23, 2012.
  1. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Once everything is welded up i will hit the floor with a wire brush and seal it up with some DP-90 epoxy and seam sealer where needed.
  2. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Finished the rocker and got the floor tacked in :)
    should have all buttoned up by tomorrow :) time for some R&R!
  3. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Floors are done:)
    4 speed looks pretty in there.
  4. Good for you man. Looks good.
  5. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Thank you did you paint that fridge yet lol
  6. Not yet. When I was cleaning the coils under it I found some of the wire insulation cracking off so I decided to rewire every circuit on it. The original wire insulation tends to fail on a 1947 fridge I guess.:rolleyes::D
    Paint will be next.
  7. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Lil more progress finished mocking up the engine and trans,next pull it all apart and blast /paint the frame.
    [​IMG][​IMG]
  8. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    OFF TO THE BLASTERS.
  9. HUSSEY
    HUSSEY
    Way cool, I see your using Carbed Gen III engine. Some traditionalist will knock those but from the articles I've read you can get some pretty easy and streetable hp out of them. Are those Walton motor mounts welded to the chassis? Did you use adapter plates the relocate the motor mounts on the engine or reposition the mounting location on the frame?
  10. 60galaxieJJ
    60galaxieJJ
    Wow a lot of awesome progress since the last time I checked this thread great job!
  11. n847
    n847
    Cool Project...Keep it up!
  12. Subscribed...brings back memories!
  13. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Thanks yes they are walton engine frame mounts welded to the frame, i used dirty dingo engine mounts to make the connection worked out real nice!And i know alot of guys give the ls the stink eye but hey it is the ultimate Chevy engine.It's actually a GEN IV engine "LY6 6.0" the l92 heads are milled and a custom cam with matching valve train this engine will put out around 450 hp easy and scream up to 8 grand! backed by a super t10 4speed and 3:73's
    oohwee! HELL ON WHEELS :)
    Thanks i try to do a lil something any chance i get to be in the garage.
    Thank you.
    sweet thanks for checking it out.
  14. HUSSEY
    HUSSEY
    That is going to be one hell of a fun car to drive! I like the idea of the LS engine. You can pick up and LM7 (5.3 Truck Motor) at a dam good price. My 216 gets me around for now but I'd like to do an LS motor in the future after I get a few other things completed.
    How did you go about hooking up your T10? In my research a LM7 has a crank that is set back 0.40 in. compared to the first gen SBC, I'm assuming the 6.0 is the same. There's companies that make custom flywheels and bellhousing to bolt up Muncie sytle bolt pattern manual trans but I've found out that a flywheel from a 4.3 or 6.0, Sachs NFW1050 is 0.40 thicker and can be had for $60. You can then use a large diameter bellhousing from an SBC or BBC but will be missing one bellhousing bolt.
  15. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    I used Kieslers LS bell-housing for the super t 10, Sachs clutch pressure plate rated up to 650 pnds of torque, and a Ram billet flywheel.
    [​IMG]Here is a peep at my cam card:)
  16. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Walton Fabrication trans mount installed.
    Now it's time to sand blast the frame :)
  17. JSanford1974
    JSanford1974
    What headers are you using? I've got a carbed 6.0, 799 heads, and a 224 cam going in my 53 Chevy hardtop.
  18. radconjon
    radconjon
    Looks good and it seems solid. and so familiar...
  19. gsport
    gsport
    wow.. how have i overlooked this thread?? nice build. i enjoy all the threads about the 49-54 cars. i'me doing a 350/350 swap in my 50 right now...
  20. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    I am using hooker headers for "98-02 F-body"
  21. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    thanks
  22. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    i am trying lol
  23. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    hey thanks for checking it out progress will be slow lol
    by the way i have been checking out your ride nice work!
  24. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Finally getting somewhere :)
    Had the frame blasted then i used por-15 semi gloss black.
    Looks good for the money spent trying to keep it within budget.[​IMG]
  25. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    your walton tranny mount looks different than mine but then I am running an automatic. a LS series motor will be replacing the vintage 327 hopefully this winter
  26. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Nice look forward to your progress :)
    I used this one best fit for the four speed.
    http://www.waltonfabrication.com/19chcar6cytr.html
  27. BadLuck
    BadLuck
    hot damn!! ur kicking butt! looks great buddy, youre doing an excellent job.. keep at it!
  28. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Thanks Man :)
  29. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    Also the radio opening was damaged at some point in the car's lifetime.
    I tried to straighten her out but no luck so lucky for me i had some extra parts out with the old in with the new.
