Projects My 40 Ford Pickup Build
Discussion in 'The Hokey Ass Message Board' started by mj40's, Nov 3, 2010.
  1. mj40's
    mj40's
    Most often I can be found in the USRI booth located in the center room on the back wall. The pickup is suppose to be close by the booth. Just ask for Mel the young dude with a almost white beard.
  2. 56premiere
    56premiere
  3. mj40's
    mj40's
    I put my upholstery hat on today and covered a door panel and kick panel.
    FlatJan and LOU WELLS like this.
  4. WOW....Looks AWESOME!!!!
  5. mj40's
    mj40's
    I had to turn the truck around in the garage today so I took the long way around the block to do it. First drive and all felt good except for a weak brake pedal spring. Every time I put on the brakes they would hang up until I pulled the pedal up with my toe. A trip to the store fixed that with a much stronger spring than I had on it. Transmission shifted like it should. Never know because it was rebuilt and I bought it from a friend who had a friend.
    I was so excited I forgot to check to see if the speedo was working correctly or the steering wheel was straight when driving. I can't stand a crooked wheel. May have to take another round tomorrow.
    LOU WELLS likes this.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    MJ40 THAT IS GREAT PROGRESS. WHEN WE DO THE FIRST DRIVE OUR EARS ARE TUNED LIKE A HUNTING DOG WAITING FOR SOMETHING TO HAPPEN!!
    LOU
  7. Mart
    Mart
    Congrats on the first drive. I have really enjoyed following this build.
    Mart.
  8. Todd M.
    Todd M.
  9. Hamtown Al
    Hamtown Al
    1. Virginia HAMB(ers)
    First drives are great... as long as you at least get back to the house!
    Sounds like yours went great.
    Congratulations on a great looking truck.
    Keep workin,
    Al
  10. olscrounger
    olscrounger
    very nice truck--it will be a beauty when done. Been there done that with 40 glass but never a pickup. Found that having my glass cut locally is the best solution and my wife and I always do the install. No cracks or scratches that way. One 40 had a set of glass from a mail order place--none of it fit-had to have it all ground down,etc. and it cost way more than local-last 40 cost $75 for both windshield pcs tinted and fit as they should.--wife and I had them in in about 20 minutes minus inside garnish.
  11. mj40's
    mj40's
    Problems today, for some reason I lost fuel delivery to the carb. New mechanical pump at the motor and new electric pump as backup mounted near the tank. Another thing to figure out. At least it was in my driveway.
  12. mj40's
    mj40's
    I'm going to replace the electric pump. I found that the one on their was from Malaysia and under $20. Probably junk and not sure if it is a flow through design.
  13. 2935ford
    2935ford
    First word that comes to mind on your interior......"sanitary" :)
    really nice job!
  14. mj40's
    mj40's
    Another good day. I had a couple friends come over and help installed the door glass, mirrors, door panels for the last time and installed the widow and door handles. I always liked the looks of the 49-50 Ford handles and escutcheons. Sure feels good to have all the glass in now with no cracks yet. You watch, the first trip I take I bet I get a chip in the front glass. Happen with my coupe.
  15. mj40's
    mj40's
    I like "sanitary" better than "clean". This turd is going to be hard to keep clean.
  16. mj40's
    mj40's
    I found my problem! The Only place I can think of to get that much water in a all new system is the bottle of octane boost I added to the tank. I bought it at the Dollar Store. Now I know why is was only a dollar. The photo is gas in a gallon jar.
  17. mj40's
    mj40's
    Today progress. I fixed the fuel problem with draining the tank and changing the mechanical pump out for a new one. The check valve was stuck open allowing the fuel to drain back. Bolted the passenger fender on and wired the headlight bucket.
  18. Beautiful.....your almost there!
  19. Hamtown Al
    Hamtown Al
    It looks like a "one eyed, one horned, flying purple--er, Yellow chevy eater!" ;)
    BTW, if you SHOULD happen to chip the windshield or brake another glass and decide to throw in the towel... I'll be happy to take it off your hands! Your new Pal, Al.:D
  20. mj40's
    mj40's
    The water did more damage than I expected. Fired her up today to clear the carb out and it sounded good for awhile until it warmed up and would not idle at all or accelerate. Pulled the top off the quadrajet and replaced the fuel pump plunger. No signs of water there and works good now!
    Checked on my fender that was to be painted and it looks like I won't have it until next Saturday. I've got 10 days until show time. I figure about a day to install the fender and front bumper and mess around with alignments. Good news is I have all sorts of friends to help me put my two 40's in the show. May cost me a pass or two. I was asked to put my coupe in a 40's is 75 display. Couldn't pass up a t-shirt and a couple passes.
  21. Hamtown Al
    Hamtown Al
    Keep workin'... we're all anxious to see the WHOLE truck! Great build. Glad to hear it is running better.
    Keep it up... you'll be crossing the finish line soon!
    Thanks again for sharing the trip with us.
    Al
  22. mj40's
    mj40's
    Thanks all for the encouragement. It really does help. I see the light!
  23. mj40's
    mj40's
    I spent the day cleaning up the truck after the buffer slung compound around. A couple photos I took today when I had it out in the sun. I also drove it around my subdivision today and all seems good.
    jnewmz, Outback, guthriesmith and 3 others like this.
  24. flyboy89
    flyboy89
    from So. Cal.
    Lookin' spiffy!
  25. Jedidiah
    Jedidiah
    from Ft Worth
    That's a beautiful truck.
  26. HiSpoke
    HiSpoke
    It looks like your reward starts to come! Thank you for sharing this project.
    Jorgen
  27. Kevinsrodshop
    Kevinsrodshop
    Awesome. I like it.
  28. 40Standard
    40Standard
    from Indy
    it just looks better and better
  29. seatex
    seatex
    Gorgeous Truck!
