My 37 Ford pickup build thread by clips221
Discussion in 'The Hokey Ass Message Board' started by clips221, Jan 14, 2011.
  1. clips221
    clips221
    Picked up my cab yesterday and brought it back home. Still no paint. It's real close to being able to squirt though. Cab's gonna be slick and painted black but the rest of the truck is gonna be put together as work in process...
  2. Roothawg
    Roothawg
    We need pics!
  3. clips221
    clips221
    Maybe this time next week it'll be black!
  4. Roothawg
    Roothawg
    Patience grasshoppa........
  5. clips221
    clips221
    Got my cab painted hot rod black last week and mounted it to the frame yesterday. Looks real decent. Now I can start with my wiring harness, steering column hookup,etc. etc. etc. 20150418_184737 (Small).jpg
  6. Jersey Larry
    Jersey Larry
    Keep up the good work
  7. clips221
    clips221
    I mounted the wiring harness in the middle of the firewall where the cowl vent used to be. Got the wires taped and ran to the rear end of the truck. Not sure where the harness is supposed to come through the firewall to the front end. there is an inch or so hole in the middle of the firewall about where the distributor is. Is this the spot to come through?
  8. Roger53
    Roger53
    Cooool truck ! Roger
  9. clips221
    clips221
    Got my grill painted over the weekend. had the fins painted silver. I had taken 2 grills and made one. It turned out pretty good from what I started with. Cranked the engine off of the dash key. that's a major milestone. All of the lights are working. Power steering is hooked up and working. Some dummy (myself) had the pressure and return lines reversed on the rack and pinion. The running boards are painted with a rhino liner type paint. Looks very good. I'm gonna leave the fenders bare metal.
    It's been like 6 years off and on working on this truck. I'm ready to drive it around the block. :)
  10. clips221
    clips221
    I drove my truck around the block this past weekend. Gas tank tied to the grill and all...
  11. Did you finally sell the '54 coupe? HRP
  12. clips221
    clips221
    Traded the 54 it off.
  13. studebaker46
    studebaker46
    you have done a slick job on the rest of why bare metal fenders? the reason I mention this is every time you go to a gathering you are going to hear NICE RAT ROD, and it is certainly not that. just some old man advice Tom
  14. clips221
    clips221
    Been making some good progress. I wound up pulling the front fenders off and having them painted..... Front end is aligned and I'm work on the rear fenders and bed sides. The patch work is almost done on them and are close to being ready to paint.
    I wound up buying a new set of throttle bodys for my 3x2 setup... I could not get the butterflies to not have vaccum leaks. new parts should be here this week. I'm gonna wait to get the engine running good before I put the front fenders on.
    One step closer.
  15. clips221
    clips221
    Couple of pics of rear fender patch work in process.
  16. manyolcars
    manyolcars
    dude! traditional hotrods dont have headlite visors!
  17. clips221
    clips221
    I will keep that in mind about the headlights. Dude.
  18. clips221
    clips221
    This past weekend I purchased a throttle body kit off of ebay. I had purchased a vintage 3x2 Rochester setup back a few years ago that was supposed to be ready to bolt on and ride. I'm just now getting around to hooking all 3 of the carbs up. could not get any justice and that's why I wound up buying the throttle body kit. It came with rebuild kits for all 3 carbs as well as the tri-power linkage setup. I rebuilt the carbs per the instruction manual supplied with the kit. the 2 secondary carbs still had all of the inner parts that I removed as well as replacing the jets. Followed their instructions for assembley, hooked up the fuel line and it fired right up. Runs smooth as silk.
  19. clips221
    clips221
    Made some good progress this weekend. I got the front fenders and all back on the truck. Still working on the hood latching but it's close. The bed sides and rear fenders are close to going to the paint shop as well.
  20. clips221
    clips221
  21. clips221
    clips221
    one last fitting of the bed and rear fenders before they head to the paint shop.
  22. clips221
    clips221
    Have made some good progress on my pickup. got the bed sides, rear fenders and tail gate painted and installed. Got the bed wood ordered, glass is ordered, hood and hood sides are being painted. she will be on the road before long...
    20160207_163655 a.jpg 20160207_163745 a.jpg 20160207_163655 a.jpg 20160207_163745 a.jpg 20160207_163754 a.jpg 20160207_163816 a.jpg 20160207_163829 a.jpg
    albertaboy and Martin_F like this.
