Technical Murphy safety switch question
Discussion in 'Traditional Hot Rods' started by birdman1, Feb 7, 2020.
  1. birdman1
    birdman1
    I have a Murphy oil guage that is also a low oil pressure switch that will kill the em=ngine if the oil pressure drops to a preset level. Does anyone know if it is adjustable? It reads from0-75 pounds, but there is a solid line on the display at 15 and 30. i have never taken one apart to see how it works, thought maybe one of you have. thanks. DSC_0036.JPG
  2. Wanderlust
    Wanderlust
    Small Allen key will move the indicator needle, gauge needs to be wired into your ignition
    Murphy32 and loudbang like this.
  3. Yup ^^^^^^
    I really never saw the need for one in your private vehicle, fleet cars and trucks yes. Most people watch their personal vehicle a little closer than that. If it were mine I would probably set it in the dash and not wire the safety part in at all and let it be a conversation piece. ;)
    harpo1313, Murphy32, loudbang and 2 others like this.
  4. weps
    weps
    from auburn,IN
    Neat piece
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I've wired up many Murphy safety switches over the years and can say if you do decide to wire it up for use it would be best to use it to energize a small indicator light or energize/de-energize a relay only. The switch contacts aren't stout enough for any heavy current flow through them and will burn up over time.
  6. hotrodjack33
    hotrodjack33
    Sounds like a bad idea on a your "street" car. Starting would require cranking it long enough to get the oil pressure up high enough to start.
    Or, hot summer day (oil a little thin) stop at a red light, get a little crud in the carb and RPMs drop too low...dead in the street.:(
    porknbeaner and blowby like this.
  7. I can't speak for how that gauge switch is wired, but if it simply grounds the circuit when pressure drops, you shouldn't run that directly with electronic ignition or you will fry the module. It can still be used by using a relay involved though. Be aware of this though.
    Also keep in mind that 10 psi per 1000rpm for RACING engines is all that's needed.
  8. Murphy32
    Murphy32
    from Minnesota
    Be aware...this gauge operates on the principles of "Murphy's Law"-
    loudbang, weps and Bandit Billy like this.
  9. BJR
    BJR
    So if it grounds your ignition with zero oil pressure, how do you start the car? Crank it until you have enough oil pressure to make the gauge not ground the ignition?
  10. 500caddy
    500caddy
    You put in a push button switch you press until you have oil pressure we had them on combines
    egads, loudbang and BJR like this.
  11. BJR
    BJR
    Makes sense thanks.
  12. nochop
    nochop
    from norcal
    Maybe on a pump motor or industrial engine that runs on automatic without direct observation
  13. lippy
    lippy
    from Ks
    Also irrigation engines. So if you left it running and forgot to check the oil level (Happens if you have 35 irrigation systems to take care of) low oil pressure would shut it down. Lippy
    nochop, egads and loudbang like this.
  14. birdman1
    birdman1
    It was installed on a 1955 tbird I bought last year. I am still using it in it, but not the kill wire. Thanks
  15. Budget36
    Budget36
    I'd guess it would be wired into the run side, I/e like bypassing a ballast resistor when cranking? Just my thought.
  16. BJR
    BJR
    That makes even more sense. Thanks for the post.
  17. rinnda
    rinnda
    Hi, you got a good point!!
    Some people do not switch on the ignition before they achieved a certain oil pressure by just cranking the engine with the starter. It takes some turns and you got it up to 20-30 or so. This could be made automatically by this gauge. Good deal, isnt it?
    In the other hand i do see the issue that If you lose oil pressure unfortunately in a situation like passing an other car it could be fatal to lose the spark in that moment. I would better have switched on just a buzzer in that moment. It gives me the decision to stop the engine as soon asbl I can. I think an engine does not get killed within 10sec with no oil pressure. But you survive...
  18. sunbeam
    sunbeam
    Most comerical apps have an over ride push button that you hold until you get oil pressure. It will also let you run the vehicle to get it out of harms way.
  19. nochop
    nochop
    from norcal
    Looks something that would add to the “ why won’t this bit*h start now”....
  20. Ford Pintos had a low oil pressure switch. You may note that Ford no longer uses one, it was a failed experiment. LOL
    hotrodjack33 likes this.
  21. dwollam
    dwollam
    We have to run an oil pressure switch on my son's O/T mini truck dirt circle racer because we run an electric fuel pump. Pump is wired thru the pressure switch. It is in case one ends up upside down, it kills the fuel pump when oil pressure drops so ya don't pump gas on a possible fire. We have found that if it sets a long time, like over the winter, that we have to pull the connector off and bridge across the terminals to make the fuel pump run. Some of the guys run a momentary switch to bypass it like someone said earlier.
    Dave
  22. birdman1
    birdman1
    i worked at a Ford dealer in the early 80's, seems like some crown vic's had then for a while?
