Muncie 4 speed Leaks
Discussion in 'The Hokey Ass Message Board' started by concreteman, Jul 8, 2013.
  1. concreteman
    concreteman
    Hi All
    I just put a Muncie in my 34 -looks like it leaks out the front -between the Lakewood bell housing and trans- car has a good rake to - low in front - any ideas (would rather not pull it)
    Thanks Chris
  2. lorodz
    lorodz
    You have to pull it and reseal the input shaft or front seal of transmission.
  3. Those only have a slinger that pushes oil back into the transmission. Mine will leak when parked on a steep downhill slope. At least that is what the transmission shop claims.
  4. fab32
    fab32
    If the trans has a bunch on miles on it they are prone to leak between the counter gear shaft and case.
    Frank
  5. mike in tucson
    mike in tucson
    from Tucson
  6. I always have a drip or two on my case. I don't like it, but I check the level from time to time it never seems low.
  7. 3Deuce40
    3Deuce40
    from Colorado
    If its a Muncie, it leaks. I have two and they both leak and both are newly rebuilt.
  8. Yup, I'll second what LORODZ and CB Chief said. You do have to pull it to do anything to the input shaft, and there is a paper gasket between the input shaft collar and the case, but only a slinger ring keeps oil from running up the input shaft itself. You might be able to isolate which is leaking by cleaning all the leaked 90w off the tranny and scatter shield, and squirting a can or two of brake/carb cleaner into the throw out bearing fork hole to get any accumulated 90w out of there, then let it sit and see if it leaks while just sitting. I forgot to mention, while your under there, pull the fill plug and make sure it's not overfilled. Level should be just even with the bottom of the threads in the fill hole when the car is level. If it leaks like this (sitting still and level, it's either over filled, or the gasket on the input collar is bad. If it doesn't leak unless you drive it, then the odd's are it's the flinger inside. I've seen them bent and/or completely left out.
  9. atorsiello
    atorsiello
    from New Jersey
    Mine has been like that for 10 years. I check the fluid level about once a year and have never needed to add any, go figure.
    Alan
  10. Truckedup
    Truckedup
    Probably leaking from the counter shaft hole. The hole gets a bit worn so the shaft might be loose and it leaks. You can loosen the bolts ,and if possible,back out the tranny an inch,dry up the oil and squeeze in some sealer between the case and bellhousing,bolt it back up ....Works sometimes...
  11. onetrickpony
    onetrickpony
    from Texas
    It's not always easy to tell, but if it's coming from between the tranny and bellhousing, it's the counter shaft hole. If it's inside the bell, it's the front gasket or the slinger.
  12. Dennis D
    Dennis D
    More apt to be leaking from the countershaft than the input. In the front bearing retainer there is a drain-back slot that lines up with a hole in the case to keep the oil from building up in that area. If that hole is filled with excess sealer it may cause your leak. If it is the countershaft I would be suprised if you get it to seal without draining the fluid before you try the RTV as it will contaminate before it sets up. Some of the best sealer I have found is sold by Toyota (sorry) and is high dollar. Part number on it is 00295-00103. Dennis D
  13. bigbob55
    bigbob55
    from Pittsburgh
    May seem like a stupid comment but can we assume the level is not too high to start with?
    Had the same complaint from a friend and when I took out the fill plug gear lube ran out the hole and filled 3/4 of a quart jar before it stopped. When I asked how he got so much lube in there to start with he filled it while it was out of the car and laying on it's side....don't overlook the obvious.
  14. Amen on the overfilling! Mine will leak a little around the input shaft when parked on a steep grade nose downward occasionally but doesn't leak on level ground at all. Prior to being rebuilt it leaked in a few places, I always told people that it was marking territory.
  15. 1934coupe
    1934coupe
    What he said!
    Pat
  16. old.hot.rodder
    old.hot.rodder
    Yes, probably leaking at the counter shaft as already said. I have repaired two of these by cleaning the cavity extremely well and filling it with a quality two part epoxy. The other way is to machine the bore and resize.
  17. concreteman
    concreteman
    Thanks Guys
    for all the help -I may try to move the trans back an inch or so
    I have an hyd throw out bearing and would need to pull the engine to seperate
    Truckedup;9045636]Probably leaking from the counter shaft hole. The hole gets a bit worn so the shaft might be loose and it leaks. You can loosen the bolts ,and if possible,back out the tranny an inch,dry up the oil and squeeze in some sealer between the case and bellhousing,bolt it back up ....Works sometimes...
    Some of the best sealer I have found is sold by Toyota (sorry) and is high dollar. Part number on it is 00295-00103. Dennis D[/QUOTE]
  18. 1971BB427
    1971BB427
    from Oregon
    My super T10 is always damp around the side cover. Never drips a drop, and never low, but no matter how often I wipe it off dry, it is damp around the cover the next day.
  19. Bosco1956
    Bosco1956
    from Jokelahoma
    X2 seen this as much as anything
  20. 60 Belair
    60 Belair
    I think when a Muncie is not leaking that's when you have to worry :D
  21. concreteman
    concreteman
    Thanks
    Starting to think your right - my only leaks a small amount now- hope the trans is not running too low on oil :eek:
