440 motor home block, crank 10/10 and rods. Virgin block Maged thrice. Beautiful stock bore. Crank turned 10/10, six pack rods, bearings and timing set. $600. Also available a set of vieniola blower pistons .60 over. With tapered wrist pins. $500. A 440 blower manifold $200. And of course a 871 GMC blower preped and never run. $350. That’s not all, there is a 440 marine block, short, run out but not broken. $300. Yes there is also a set of Holley 660 center squirter carbs number matched $500. The blower motor sat as a mock-up for years, but the boat hull disintegrated faster than it could be repaired. Thus the project went south. Good Luck with your projects, sure has been a lot of fun.
