om frame built from CCR T Bucket plans (though we did extend the back rail for the original intention of using a 27 T or T bucket with a turtle deck). Probably could work as a frame for a Model A as well . I can provide build pics. Rebuilt Dana rearend with 3.55 gears. Farmall Tractor Grill. 30-31 model A headlights (converted to sealed beams) plus a set of huge headlights of unknown make, Complete front brake kit from Speedway motors-Ford bolt pattern (never been installed!). CJ 5 gas tank and instrument gauge. GM steering column. Reversed and rebuilt Corvair steering box (the later model steel box, will need the steering shaft shortened to use the GM column). Custom radius rods. reversed eye 32 ford front spring. Model A stock axle. Custom built suicide front perch. MG lever action shocks (supposedly rebuilt). radiator. Fenton shifter. I've got a pair of seats that I will throw in as well (not pictured, a set of buckets and I have a bench seat). There's a lot of other odds and ends I've collected for it that will go with it. There is no body. As I said in the first part, EVERYTHING goes. 1000 or best offer . No trades.
