Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    Some shots before going in...
    tempImageXejqHr.png tempImageLG5q8l.png tempImageJvZG4j.png tempImageVdhRXj.png tempImageIE3V0x.png tempImageA7WPRG.png tempImageMsxLlU.png
    2Blue2, patmanta, LAROKE and 2 others like this.
  2. alchemy
    alchemy
    That pulley looks like it's made for a 39 and older fan. You have a later fan. The earlier ones come in different lengths, usually the later the shorter. I'd think you need short.
    As for your linkage, that looks really screwy to me. Why have two different length arms on carbs that should be equally linked? And, are you sure you put the spring on the correct direction? I like to buy my linkage stuff directly from Stromberg, through their favorite dealer Uncle Max Musgrove.
    pennafxu likes this.
  3. pennafxu
    pennafxu
    from Kentucky
    brEad, 2Blue2 and loudbang like this.
  4. alchemy
    alchemy
    I didn't even watch your video. Charlie's Price is not the guy I trust to supply good parts or information.
    You have such a widely spaced intake manifold that I don't believe using a carb clear on one end to supply both ends will give an equal mixture. I'm no hydraulogist or pneumismotist, but it seems to be counterproductive to me.
    Stan Back, Tman and pennafxu like this.
  5. pennafxu
    pennafxu
    from Kentucky
    Ok I’m just buying the stromberg one, where do I measure from and do I buy a progressive one like the one I have?
  6. pennafxu
    pennafxu
    from Kentucky
    Is this a short fan? 4DE429B3-D506-4E73-A8EE-5AD9F78C8490.jpeg 448FAB50-D9F0-4338-8022-A6B74FBD83AF.jpeg 0DD2CA28-E09D-405A-B194-373A5FAB87F8.jpeg
  7. Dick Stevens
    Dick Stevens
    As @alchemy said and I agree wholeheartedly, it is a mistake to do progressive linkage.
  8. alchemy
    alchemy
    That is the proper type fan, and it seems on the short side. But that one looks really rust pitted. Never trust a suspect fan. Too dangerous to have risky steel spinning in your face. Ford made millions of them, and there are still good ones out there.
    To measure for the proper linkage, string a rule from the shaft on the front carb to the same shaft on the rear carb. You need to know the spacing apart they have. That is the number the manufacturer will want.
  9. pennafxu
    pennafxu
    from Kentucky
    patmanta and loudbang like this.
  10. 1930ModelA
    1930ModelA
    That is not the short fan. See pic. This one is nice and available, PM me if your interested. Also as mentioned go with the straight linkage on your 2x2 set up, not the progressive. F5639869-92B1-4C6F-BCAB-588B79FCDCF8.jpeg 305A6DBF-9F9C-4E6A-89E1-1A971A2EC6E8.jpeg
    loudbang and pennafxu like this.
  11. pennafxu
    pennafxu
    from Kentucky
    I’m measuring the linkage today as per @alchemy. Is this the correct belt? 4E9224D0-8472-49C8-A97F-37CC281EEBEA.jpeg 014060F9-5499-43D9-8CB9-68A963FFE832.jpeg
  12. pennafxu
    pennafxu
    from Kentucky
    A05311AF-3AE6-4548-ABF4-46EEC6394731.png 0D29DCCF-3EA4-451C-9356-A9C5A5AA7400.png Is this an acceptable radiator for my test stand? What are the two lower openings for?
  13. alchemy
    alchemy
    Penn, that gray fan is for a 40 and won't fit the pulley. Note the mounting surface has a protrusion, not an inward bore. The next one shown by 30A should mount up just fine.
    I personally don't like aluminum radiators, but as you know I'm a purist. It should be just fine for a run-in stand. If you are using an electric fan as shown on that radiator, why worry about a mechanical on the alternator? The two small fittings on the radiator are for an automatic transmission coolant connection.
    Wait til you have your parts assembled, stretch a tape measure around the pulleys, and take that measurement to your local parts store and buy a belt. Also buy one an inch shorter and an inch longer. Take back the two that don't fit. Kinda dumb to buy a part meant for a stock engine while you are switching around a bunch of parts, expecting it to fit. And paying shipping on top of it.
    brEad and pennafxu like this.
  14. pennafxu
    pennafxu
    from Kentucky
    @alchemy Thank you for all your help during these trying times for me. I appreciate the knowledge!
  15. pennafxu
    pennafxu
    from Kentucky
    After my flathead cooling book it said you can't get enough cooling on a flathead... I was going to run both as per the information. More to follow after some break-in runs. I also like the look of the fan for nostalgia...
  16. pennafxu
    pennafxu
    from Kentucky
    Do you know what width?
  17. alchemy
    alchemy
    I believe they are called 5/8"
  18. OK, well then I would say a flat front crossmember with a reverse eye spring will get you another 2-3" down in the front. That or ditch the spring over, add a piece of 1x2" box tube between the horns, and run a spring ahead setup to get LOW. Here is my AAV8 where I have a setup like I am describing. My axle is an old one and not as low as yours. My crossbar also needs to come up to the top of the rail still (I tacked it to the bottom jic I went too low; I did not), and I am not running a reverse eye spring. On your car, this would drop your front end WAY down from where it is now.
    I will drop down another 1.5"-ish when I move the crossbar up. A reverse eye spring would make that drop between 2 and 3" more on top of the 3ish inches a spring-ahead gets on its own. You can get down around 9 or 10" iirc.
    Also bear in mind a couple other things, you are not on a 32 frame, so getting that look on a Model A frame is not really going to be easy. And I also wanted to mention that if you channel your body down, your grill shell should come down also, which determines what radiator you will need.
    2Blue2, loudbang and pennafxu like this.
  19. pennafxu
    pennafxu
    from Kentucky
    Ok a 32 frame? That's my next project then! I need to just finish this one out with channeling... What chopped radiators for a 32 shell and 53 flatty? @patmanta
  20. There are a lot of options and I am not familiar with them all. But "chopped" 32 radiators are readily available online for short money. I suggest making a few mockup templates out of cardboard based on measurements of what you can get. I wouldn't go down more than 4" which you can do with that cowl you have there if you trim the firewall. Once you get that down you will be able to get a line on how far down the shell needs to go and how you want to get it there. You can section it or just cut some out of the sides on the bottom and drop it lower (which is what I suggest you do if you want to use that chromed 28/29 shell).
    But I would focus on stance first really. If you want to get down LOW, the easiest (LOL) way is what I said with the spring ahead and flat bar (or a piece of channel to get even lower!) crossmember in the horns. You retain your existing crossmember and wheelbase so you keep your radiator mount too. You would want a set of 35 to 48 wishbones, with, I believe, 35/36 being closest in length to Model A bones. IDK what your axle is, so you need to figure out which one will fit on there. Once you get a set of split bones on the car with the correct geometry, you will need to heat the perches and bend them so the spring and shackles sit perpendicular/parallel to the crossmember. On my truck, they bent the bones themselves which is another way to do it (though it may be a controversial one).
  21. pennafxu
    pennafxu
    from Kentucky
    tempImagefWZTCt.png Measured the carb linkage distance and it came out to 9 5/8" I also got the other linkage figured out! :rolleyes: However I'm still going with the direct.
    2Blue2 likes this.
  22. pennafxu
    pennafxu
    from Kentucky
    Added my choke set up...
  23. pennafxu
    pennafxu
    from Kentucky
    Found some nice SS acorn nuts 5/16" fine thread... tempImagemysDa4.png
  24. pennafxu
    pennafxu
    from Kentucky
    Pulley bolts...
    LAROKE, patmanta and loudbang like this.
  25. pennafxu
    pennafxu
    from Kentucky
    Radiator options @alchemy Why the two openings? Will this suffice for my stand?
    0FC2ECFB-12D9-4E10-A7FD-1010E65AF0F4.png A9837B91-92F5-453B-884B-5657F47007E7.png
  26. pennafxu
    pennafxu
    from Kentucky
    I'm looking to get this for the actual car... @alchemy Also will this cap work? B19B9CA9-33A8-4DD8-8C49-C4C5ACF720C0.png 00E3F06F-A4B1-4FF4-86D2-C4963B667E94.png
  27. alchemy
    alchemy
    I don't understand what you mean "why the two openings"? There are two hoses top and bottom on a flathead Ford. Have you looked at your engine?
    Make sure to measure what diameter your hoses are, as the radiator might be wrong. Early and late flatheads had different measurements.
    And I've got no idea if that cap will fit that radiator. You should probably contact the manufacturers.
  28. pennafxu
    pennafxu
    from Kentucky
    On the top bulkhead of the first radiator picture there are 2 openings… is one the filler, if so what is the other one fit? Is it for an overflow tank?
  29. alchemy
    alchemy
    It's fake on top, just a place to put the original style cap.
    patmanta likes this.
  30. pennafxu
    pennafxu
    from Kentucky
    553EBE54-F0A8-47CD-B5FF-346920717BD0.jpeg 3E991115-3B65-49C2-8FB8-EA563F3B1417.jpeg Stromberg really packed its parts nicely... :D Fan came in also... Will make a custom shroud later tempImageKjtMB9.png tempImagetqpjGL.png
    AHotRod, brEad and patmanta like this.
