It might have been built to use in the snow or muddy fields. I doubt it's worth anything as a cobbled up contraption.
drag it outta there and get a better look as to how it was built and post lots of pictures just my 2c
Ah Menomonie, I miss that town sometimes.... Had many great times there. Cut the axles off and make it your own.
Model As were turned into all sorts of tractor/doodlebug/transsexual contraptions years ago, when you could buy one for $5-$10. The axles themselves may be worth a few bucks, depending on what they are.
hell at a minimum you got a body..and something strange under it all..Give it a home, and tell us what your plans are for it
The axles were built into it. I believe it is an ARP Conversion, but Im not sure. I have seen pictures on here before though.
Collectors are looking for ARP conversions and parts, if that's what it truly is, somebody somewhere is probably interested in those parts.
The back half is 28-29 Ford while the cowl is a 31 Ford. It is on a 28-31 Ford Frame. It's worth dragging out and salvaging parts.
I have looked at allot of pictures of an ARP conversion and I'm sure that's what I have. Even has the funky front hub for the ski's. How do you know the rear is a 29? I actually have a 29 tudor cowl and doors!
You could buy snow tracks to fit over the 3 sets of rear tires but usually they would fit skies to the front axles.
Don't know what the rear fenders are on it though,,they called em "Snowbirds" Mostly don on Model T's ( 4 rear wheels ) ,,but also done thought the 40's I would grab the whole thing and very carefully at that,, look and see if it has the turn buckles just behind the front wheels
they are not axles just placed under... If u look close. The rear of the body was just set in place. There are two sets of sub rails. The ones from the rear are at an angle hanging in the air. So the fender was an after thought. It wasn't used for snow so that's why the skis are gone. I am 90% pos it is a ARP conversion. But who can confirm that the rear is a 29?
Again! Fender is after thought. There is one subrail sitting over another subrail. So someone added the rear section at some time. It lifts right off with little effort. The frill shell and radiator is siiting in the garage too! All the fins are in good shape!
from the pictures it looks like the 2nd axle took most of the load. why not resurrect the multi axle look from the mid 80's mini trucks. or snarf 2 skid steer setups from a couple of bobcats. be the only kat in town with a skid steer hot rod.
Carefully remove every bit of that car and put it on the market if you don't want it yourself. Snowbirds have a fairly big following these days.
Snowmobile ,maybe tracks over the tires / boggies ? Skis on the front for snow,tires for mud ? Get and take it home for many hours of research and beer drinking .
It does have the turn buckles! and there is chain and track material laung everywere... I will let it go, All I want is a drivable madel A chassis! I can take much more pictures next weekend!
If it wasn't in Wisconsin and me in NY I'd be asking for directions already. What the hell, if you're going to leave money laying there on the ground, I have no problem going and picking it up and turning it into cash. Which I mean, that's basically what it is, a stack of $100s laying in the woods, if it's not what you want it's just as easily either sellable outright or tradable for what you do want. Yeah, it's a little more difficult to pick up than a dollar bill, but that's how you earn your pay on it. No, you're not going to retire on it, but you'll be at least $500 ahead and probably more when you're done. *scratches head*
Sure is an ARP/snowbird . Not often seen in their natural habitat. The two middle axles won,t be much use as they have been lengthened to hang outside of the car. The front and rear axles will probably have these things bolted on. The units on the rear are pretty heavy. Once removed you have a normal axle. Same for the front axle.
So, could it be an ARP chassis with the skiis removed and road wheels put back on for use in warmer weather? Gary
Look at the beltline. 28 - 29 is flat, 30 - 31 has some contour in it. Pic is left corner back, only pic I had on hand
Those axles havent been lengthened. They are the same width as the rest. The vehicle was used in a marshy area for harvesting. So I do not believe that there would be any ski's with it unfortunatly. I would trade anyone with a 28-29 pickup!
OK , i,ll put it another way. In the second pic you posted you can see that the rear wheel is way outboard. Thats because of the reduction unit that is bolted to the end of the stock rear axle.The middle wheels have to line up with the back wheels so that the tracks will fit. Thus the middle axles will be longer than a normal I beam front axle. Maybe they are just 2 inch solid square steel.
