Hot Rods Model A front ride height concerns
Discussion in 'The Hokey Ass Message Board' started by louder50, Jun 28, 2020.
  1. louder50
    louder50
    from Michigan
    I've got 3.5 inches ground clearance on the lowest point of the axle and 3.25 inches on the lower shock mount nut. The scrub line is ok even if the tire blew of the rim completely everything would be sitting on the rim, not the axle or shock mount. Is that enough clearance to be safe? 20200628_121311.jpg
  2. Hnstray
    Hnstray
    from Quincy, IL
    @louder50
    Are you saying you have a tire side wall height of less than 3.25”? Because it has to be less than that if, in case of it’s absence, everything else would still be above ground level.
    Ray
  3. Just stay off them dirt roads going to Diehls cider mill
    Hnstray likes this.
  4. The37Kid
    The37Kid
    I'd be a lot more worried about the front crossmember to frame attachment.
    Bob
    Hnstray likes this.
  5. Hnstray
    Hnstray
    from Quincy, IL
    Good catch! Although, expanding the photo, it does appear there is a boxing channel/plate in there. But there is room for beefing a bit more.
  6. Jmountainjr
    Jmountainjr
    It's hard to tell from the picture, but I'm not sure that you meet the technical definition of keeping all suspension components above the scrub line. How is the oil pan clearance?
  7. louder50
    louder50
    from Michigan
    The frame is a Brookville Roadster model A frame. I bought it from them at a show.
  8. flamedabone
    flamedabone
    It looks like about the same as a million other hot rods out there with short tires and a drop axle. If you need some additional lowness, you can flatten the crossmember without affecting the scrub line.
    -Abone.
  9. Let the air out of a front tire,and see what you have left.
  10. raven
    raven
    There are always trade-offs when running a lowered car. Just how much depends on how low you want to go.
    r
