Like to know what backspace wheels you guys with s10 rears are using i want to go 7 inch wide rim with 235 75 15 on rear I’m running fenders so need a backspace that wont rub inner or outer edge of fenders. I know a few of you are using the s10 rears but I don’t remember reading anything about the backspace. If there is a thread on this that is ok too. Thanks. It’s a 31 coupe
I don’t think so I’ve read on threads here that guys are running that size but they never say what backspace they are running. That is what I’m trying to find out.
I have a 26 T with a 97 S10 2wd rear and 235 75 R15 tires . I reversed 7 inch wheels and have 2 3/4 inch back space. Not on the road yet but can not see any problem. Could actually go to a 8 inch wheel and keep the tires inside the fenders
Thanks kr, i heard 3 3/4 but that seemed a little close to the inside. Hoping i can get a few more responses cause I don’t want to make a big money mistake.
I have a S-10 2WD rearend (about 54" at the wheel mounting flanges) that I was going to use in my '31 Coupe, but I decided a different route. Based what I came up with when I was trying to figure things out on the rearend width, tire selection etc., I agree with what krgdowall said in the post above. Lynn
Jaw 54 3/4 i think Carnut.com has a rear end width chart for a lot of ford gm and Chrysler rears if you need something else.
You should pull out your own tape measure and measure your own car. I wouldn't trust somebody else's measurements when I have my own car sitting in the garage.
What do you have so far? if you have the rear in the car; bolt on a fender, set a tire under there, and do a little measuring. Should be able to come up with a plan. You may have to spread and block the tire to simulate the rim width. Oh yeah, you should specify coupe/roadster or sedan; wheel wells are kinda different between the two.
Yeah sorry about that its a coupe. Hoping someone that runs them had the setup right I’m thinking about 3 1/4 but sure would like to find out for sure.
I was going to use an S10 rear end under my 30 and after I mounted it I still needed about 2" spacers behind reversed rims to clear the body. I also had mocked up a S10 5 speed behind my flathead and didn't like where the shifter came out and went back to an early ford trans and banjo rear end.
