Can anyone tell me which MINI STARTER would bolt up to a 1960 283CI with a 4L60 transmission. ¿ DOES IT TAKE THE STRAIGHT ACROSS PATTERN OR STAGGARD PATTERN?
http://www.novak-adapt.com/knowledge/chevy_standard_shift_info.htm If your block is drilled for straight across, use a Denso Mini starter for a chevy Most are multi drilled for both flywheel sizes. And they have enough grunt to load a car on a trailer using the starter
I got a 1958 283 that I want to install a T700R4 behind so I'll be interested to see what starter issue there maybe!!!
As per the picture above............FLEX PLATE has 168 teeth. I tried the POWERMASTER 9100 with STRAIGHT bolt pattern, whicH is suppose to work on both 153 and 168 flexplates. NO WAY will it work. Either too close to the flex-plate or too far to make contact with the flex-plate. I read somewhere that with the 283CI and 700R4 the STAGGERED bolt pattern is needed. SOMEONE MUST HAVE DONE THIS ALREADY???
all the mini starters i have used had two sets of holes straight across. you used the holes that lined up with your flexplate
Did you ever place a mini starter on a 283CI that had a 700R4 transmission ?? Someone out there must have............I can't believe I'm the ONLY one doing this. So far, my research is leaning towards the STAGGARED pattern starter. I will find out very soon! Thanks a bunch for the input, Mike
From the link posted earlier by Kerrynzl http://www.novak-adapt.com/knowledge...shift_info.htm It states; On 1955-1961 V8's the aluminum bell housings can be used by having the block drilled and tapped for the starter. This must be done also on 1955-1961 V8's when using these engines with Turbo 350 or 400 or 700R4 automatic transmission, as these transmissions were always used with block mounted (1962 and newer) starters.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o> The cast iron bell housings with flange mounted starters can be used on all V8's 1962-on. These can be used with block mounted starters by grinding the lower portion of the housing to clear the block mounted starter casting. <o></o>
MY PROBLEM HAS BEEN RESOLVED- The correct starter to use on a 1960 283CI block with a 4L60 transmission (700R4) is the MINI STARTER with the STAGGERED bolt pattern. There's a reason why they make the STRAIGHT and STAGGARED bolt pattern for a 168 teeth flywheel. Thanks for all the input........... LG, Mike
