Mercury Flathead Intake
Discussion in 'The Hokey Ass Message Board' started by 2935ford, Feb 14, 2011.
  1. 2935ford
    2935ford
    Pardon my ignorance. I did check the tech section but did not find anything related.
    I have a late Mercury flathead intake with the weird 4 bolt Holley carb.
    Are these intakes good for any other carb besides this one?
    If so, which and anyone running this combo and if so, do they run well vs. the standard run of....94, 97 etc. or 390 4bbl?
    Any input would be greatly appreciated.
    Thanks.
  2. moefuzz
    moefuzz
    Mercury adopted the Holley 885 carb (with 4 bolt base) in 1949.
    There are at least 7 or 8 variations of the 885 as used up until 1951.
    For 52/53 (54 in Canada) the Holley 1901-ff carb was adopted of which there were also about 7 or 8 variations.
    In 54/5 the Holley 2140 was introduced into the overhead valve V8 engine line. It also features a 4 bolt base but the 2140's base is almost a square pattern while the earlier Flathead based carbs featured a rectangular base plate. They are obviously not interchangeable.
    None of these 4 bolt base carbs are very desirably and parts/service kits for them are limited.
    Michael Moreno likes this.
  3. tiquer
    tiquer
    Two barrel Rochester early Chevy (283-327) and some Dodge carbs are a bolt on or miner fussing to get to fit. Or with an adapter a holly style(Motorcraft) two barrel will work. Will post a pic latter.
  4. Destralo Roach
    Destralo Roach
    The new two barrel Demon should bolt on and is by far the best two barrel out there, buddy of mine just put one on his 49 coupe and no problems!!
  5. 2935ford
    2935ford
    Thanks guys. I don't want to run that carb....it's butt ugly! So, it's a shelf item.
    The Rochester 2bbl plentiful, rebuild kits and reliable? Are they prone to leak like the 94, 97 etc.
    What type of air cleaner/filter top?
  6. 2935ford
    2935ford
    I'm not a carb wizzard and I'm running a Holley 390 on my other 50 Flatty in my 35 Slantback. Has been good so far. Since I have the Merc intake manifold.....and wouldn't mind someting a little different.........
    I'd like some bolt on and go carb out of the carb.
  7. Destralo Roach
    Destralo Roach
    Two barrel Demon.......
  8. 2935ford
    2935ford
    Guees I should mention...this would be going on a 59A flatty.....I would need a riser?
  9. 19Fordy
    19Fordy
    I am pretty sure the 49-53 8BA Ford intake will bolt right up to your 59AB. Then just add your 3 bolt 94 and you're "good to go."
  10. barry wny
    barry wny
    I have one (merc manifold) &a '42 caddy 326 V8 carb on it, I suppose you could use any 283/265 carb. I thought it will be cool to rebuild a late motor with mild cam & the bigger 2bbl. The upside down carb ISA stupid thing, my buddies IH dump truck has one of those goofy things on it, a bitch to keep from flooding when warm... Like Quasimodo they just don't look normal
  11. 2935ford
    2935ford
    Thanks, I have all 3 intake manifolds (59A, 8BA and the Merc) so I'm good there. Just wondering if I could do a different and "better" carb. Don't know that Rochester or Demons are "better" but I really want reliability and no "leakers".
  12. speedy pete
    speedy pete
    Here is A rochester 2g on a Merc 4 bolt manifold. Runs great.
      281.2 KB
  13. bobscogin
    bobscogin
    It's a good, cheap manifold for a mild hop-up. I'm assembling a '42 Merc 239 and am using a '49+ Merc intake with a 2G Rochester. The Merc intake seems to have better runners, and the small base Rochester 2G will flow about 278 CFM. That's quite a bit more than most 3 bolt carbs. You may already know this, but you'll have to address the difference in the way the intakes handle crankcase breathing.
    Bob
  14. 2935ford
    2935ford
    speedy pete....that's cool......I like the look.
  15. 2935ford
    2935ford
    no....I did not know about the intake breathing issue?
  16. Buz
    Buz
    I also had a Rochester 2 bbl on my 50 Ford and it ran great. The rebuild kits are cheap and easy to install. The carb is not a leaker I ran it for a few years and never touched it.
  17. 2935ford
    2935ford
    Breathing.....oh, you mean the 59A at the back and the Merc intake at the front...gotcha.
  18. FlatheadFanFromMI
    FlatheadFanFromMI
    If you already have one, dont be afraid of the 1901. i've used one on my 53 merc for the past 10 years with no issues. the rebuild kit was readilly available. they are prretty ugly though.
  19. Flat Roy
    Flat Roy
    I also ran a Rochester 2brl on my Merc manifold. And it worked great.
  20. 2935ford
    2935ford
    thanks...for the Rochester 2G what mods were necessarey? Did anyone use an automatic choke? What to look out for when buying the carb?
  21. 2935ford
    2935ford
    gee....I have a lot to learn about the 2G...small base, large base, long shaft ,stage, bolt pattern?
    I'm confused.
  22. dickster27
    dickster27
    from Texas
    If you use the 2G, which is a great little carbie for your motor, you will have to install an extended throttle shaft so you can hook the factory linkage up to the right side as the original had. But, why go through all that trouble when you can simply use a 4 bolt 2110 Holley 94 that will give you the good looks, same performance and no jimmy-jackin' linkage, plus they take no special tools to rebuild.
    Just remember the KISS theory.
  23. 2935ford
    2935ford
    thanks, this will go on my roadster as I am using the full hood....won't see it.....a Rochester 2G is probably my answer.
  24. 2935ford
    2935ford
    thanks, didn't know about the linkage....nothing is easy! Shouldn't a cable throttle solve that? I have a 94....I just don't like "leakers" and sooner or later...they all seem to leak! My Holley 390 has been on since '07 and looks like new! I want reliability and decent performance.
  25. Also the 1942 and up Lincoln/Zephyr V12 carb are a 4 bolt base that will bolt strait on to your Merc intake and work well too.
  26. bobscogin
    bobscogin
    Merc intake with 2G on my 99A Merc.
    Bob
  27. 2935ford
    2935ford
    thanks.
    are they plentiful and inexpensive and rebuild kits available? what make are they?
  28. 2935ford
    2935ford
    cool
    how do you upload a pic from your computer?
