Master cylinder question!!!
Discussion in 'The Hokey Ass Message Board' started by 31pickemup, Sep 28, 2006.
  1. 31pickemup
    31pickemup
    Hello All,
    I'm running 12" Lincoln brakes with buick drums in the front and a 8" Ford rear out of a 63 comet. They are 10" brakes. What master cylinder do I need for this setup (year etc.)? Do I need a proportioning valve as well? Thanks
  2. BobbyD
    BobbyD
    from Belmont NC
    What are you putting them on, the '31?
  3. 53sled
    53sled
    from KCMO
    Find out the bore sizes of the wheel cylinders and you should find one that is close. I would guess a 7/8 bore master, like a 49-54 chevy under floor would work. if you wanted a dual, you can mount a chevelle 4w drum master behind a gutted stock one and retain the pedal setup. I did this with a 1" vette master and kept it all looking stock.
  4. 31pickemup
    31pickemup
    Yes this is going in my 31
