I'm doing a final assembly on a new project. Has anyone found a brake fluid resistant coating that I could use on a master cylinder?
Mine has hah Eastwood cast iron exhaust manifold paint for 5 yrs and still looks great. I'm careful not spill anything on it. You can see it is slightly different color because there was no repeated heat curing, only the first time in an oven.
Eastwood sells a paint specifically for master cylinders that is brake fluid resistant. It only comes in gray. http://www.eastwood.com/eastwood-brake-gray-aerosol.html
