Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. Wow, it almost looks like you guys know what your doing:rolleyes:
    Unbelievable Workmanship!
  2. tmfcracing
    tmfcracing
    from Sweden
    It "almost" looks like spagetti but I'll think it will turn out different ;)
  3. tmfcracing
    tmfcracing
    from Sweden
    Off Topic but i got to show you this, I made a foot/stand for a customer of mine.
    She is an sculpture artist and have made this stainless diving teaddybear. Cool :)
  4. TurboX2
    TurboX2
    First glance I thought it was something else! Your car will be a big hit when you finish!
  5. tmfcracing
    tmfcracing
    from Sweden
    Todays work , post under trunk corner. I like some radio and the speakers wont be visable from the trunk or inside the car.
  6. tmfcracing
    tmfcracing
    from Sweden
  7. tmfcracing
    tmfcracing
    from Sweden
  8. tmfcracing
    tmfcracing
    from Sweden
  9. original hotrod 32
    original hotrod 32
    from england
    look like new shifter knob
  10. tmfcracing
    tmfcracing
    from Sweden
  11. jefscoupe
    jefscoupe
    Great idea on the speaker mounts.
    The sculpture, I had to look at it a while before I saw the bear.
    Great work on the stand for it. :cool:
  12. tmfcracing
    tmfcracing
    from Sweden
    Battery Box, battery is Odyssey pc680. Very slim :)
  13. tmfcracing
    tmfcracing
    from Sweden
  14. tmfcracing
    tmfcracing
    from Sweden
    The best ting is that this battery fits behind the interior.
    brEad likes this.
  15. absolutely incredible attention to detail. you must hear this alot but wow. so much talent, I'm 23 and building hotrods and i hope in 20 years i have half the talent you do!
    the e-brake looks great. would love to see something like that as a suicide shifter outside the the cab idea.
  16. KICKSY
    KICKSY
    Just viewed this build thread front to back, truly outstanding. A joy to
    view, well done.
    Dave.:)
  17. brady1929
    brady1929
  18. tmfcracing
    tmfcracing
    from Sweden
    Thank for you comments guys :)
    I found some parts from an old Heater, belive it was used in a tractor. It is only the front panel and the "radiator" or whatever it is called ;)
  19. tmfcracing
    tmfcracing
    from Sweden
    First thing I did was a aluminum bezel for the front in 1/4" alu.
  20. tmfcracing
    tmfcracing
    from Sweden
    Now I got the round edge mill in the drilling machine and it makes it saves time when grinding :)
    The endmill has a ball bearing in the bottom and it rolls on the edge when putting the parts against it.
    If you wants to try this, be careful. If it hooks, the parts will hook hard and fly far far away ;
    The solution is to lower the mill very little each time and dont heditate to remove to much material at once. Hi rpm and cutting oil is needed.
  21. tmfcracing
    tmfcracing
    from Sweden
    This is how it turns out after the milling, a good start for grinding.
  22. tmfcracing
    tmfcracing
    from Sweden
    All the parts with the things I made for the backside of the heater and the computer fan.
  23. tmfcracing
    tmfcracing
    from Sweden
    Started with rolling the long sheet and tack it to the backside part.
  24. tmfcracing
    tmfcracing
    from Sweden
    Welded and grinded.
  25. tmfcracing
    tmfcracing
    from Sweden
    Some paint and the fan in place.
  26. tmfcracing
    tmfcracing
    from Sweden
  27. tmfcracing
    tmfcracing
    from Sweden
    Someting like this but with other screws and the lids is still not there.
  28. tmfcracing
    tmfcracing
    from Sweden
  29. McFly
    McFly
    Wow! That turned out great.
