Hot Rods marginal power brake performance
Discussion in 'The Hokey Ass Message Board' started by big john d, May 27, 2024.
  1. big john d
    big john d
    from ma
    has anyone used a vacuum reservoir or an electric vacuum pump to help power brakes when you have a big cam
  2. jimmy six
    jimmy six
    General Motors comes to mind with the earlier tuned port injection. I had a couple of the pumps I bought at swap meets years ago and the worked pretty good on a small engine crankcase evacuation system…
  3. I've been happy using an electric vacuum pump to make power brakes work. I suppose a mechanical pump would be ok but it means adding quite a bit more hardware.
  4. Mr48chev
    The newer GM performance cars with blowers = Cad CTS V have a vacuum pump on them to provide vacuum to the booster. back in the 7.3 days Ford Diesel pickups had a belt driven vacuum pump for the booster. A number of cars had vacuum reservoiur cans back in the late 60's and early 70's though.
    The aftermarket electric vacuum pumps aren't all that spendy do a search for Cadillac CTS V vacuum pump. One listing even will give you a listing of possible donors if you want to go scrouging pick a part.
  5. big john d
    big john d
    from ma
    do these pumps run all the time or do they cycle as needed to maintain the necessary vacuum
  6. A Master Power vacuum pump I just installed only cycles enough to meet demands.
  7. As needed, I believe mine kicks on at 16 iov and off at 22 iov
  8. jimmy six
    jimmy six
    Not psi…. Inches of vacuum.
  9. As noted above, a vacuum switch cycles the pump on and off as needed.
  10. Sharps40
    Sharps40
    A reservoir alone won't increase performance, rather it just adds several more cycles of the pedal at engine vacuum.
    A pump alone will increase performance.
    A pump and reservoir is better.
    A pump, reservoir and biggest booster you can fit is best.
    My 7" dual was marginal, even with can and pump on a 3600 lb car and 20" vacuum.
    Going to a 9 in dual with pump and vacuum can made the brakes amazing. I also ditched the cheesy switch in the kit and used an adjustable trans vacuum switch for best reliability.
  11. gimpyshotrods
    gimpyshotrods
    Hydroboost.
    Hydraulic brake booster, that runs off of the power steering pump.
