I'm re-doing the brakes on my channeled '32 5w. The previous owner had the M/C under the floor with the pedal to the left of the column, (real close) which could be a problem in a panic situation. I don't left foot brake, and I'm thinking of putting a swinging pedal in. Is there a pedal asy. available for an under floor mount through the floor for the right side of the column, that someone could recommend, or would it be best on the cowl?
Good question. I don't like them to the left of the column either. I like swinging peddles real well but I have modified peddles that I have found on the wrong side of the column or moved the assembly over if there was room. Moving the master is your better option I am not sure who makes a kit for one that way though.
