Technical Lowering the rear of a Tudor
Discussion in 'The Hokey Ass Message Board' started by novaskilling, Nov 15, 2021.
  1. novaskilling
    novaskilling
    I have a 30 sedan that I’d like to lower the rear suspension 2-4” without channeling the body or modifying my frame. Are there any options available to me that don’t involve buying an expensive custom leaf spring? I’ve seen the T spring swap but am a little unsure on how to make up the difference in width? I’m running a 40 banjo rear that’s been converted to spring over using stock model A perches.
    thanks!
  2. You could take some leaves out of the spring you have, and reverse the main leaf, assuming it hasn't been reversed already.
  3. oldsman41
    oldsman41
    If this is your first rodeo with model a springs you want to search the method of getting them apart safely
  4. wheeldog57
    wheeldog57
    Listen to these guys^^^ use extreme caution if you plan to remove a spring perch bolt. C- clamps and spring removal tool a must unless you like massive injuries. Good luck
