Looking for a lower radiator hose for a 32 ford w/ a 327 chevy .Short water pump.Bought one from So-Cal speed shop . The bend was shaped correctly but the rise in the hose was to high.
Take some dimesions of what you need, take your tape measure and head to the local parts store. See if they will let you look through the hose shelves and find what you need. Ever so often if you tell them what your trying to do a counter person might recall an application that works. Also, keep in mind you might have to cut a section out of a multi bend hose. Frank
I like to use a Gates #20225 and I have to trim a little off the ends. I believe the 55 Chevrolet ( V8 ) works also ... with trimming. But I have found that the Gates #20225 works on most everything OLD Ford with a SBC. I used the same number in my 40 Ford.
look at one for a S-10 4 banger, you need to cut a little off the radiator end. Sorry I dont have a parts number there is too much snow to go out and look now. Later Russ
