can you louver a piece of steel and weld a flat sheet under it to keep the water out? i like the way the louvers in a deck lid look but worry about the water. is there a way to do it and keep the water out?
If you have a beed roller, you can get a louver die. I know Eastwood sells them. I have been wanting to try this for a while, but can't afford the dies just yet. I was thinking louver a panel, and weld it on top of the existing panel(or splice into), hood decklid, or whatever. I think the die set is like 60-70 bucks.
kinda what i was thinking about. laying a louvred sheet ontop of a plain sheet of steel but wondered if any one has tryed it or if anyone had a better idea?
I would think trying to "mate" two pieces can run into trouble in two ways. One would be the chance of flattening some of the louvers, second would be a real clean "join" between both pcs so you dont have any humpy spots where the metals wont join. Not an expert on say using any of the automotive body panel adhesives, but at least you wont warp any metal. 2 cents. worth
When you put a sheet of metal under a top sheet with louvers unless you seal all surfaces rust will eventually form between the panels. One way to seal out the water is to get a sheet of the flexible magnet material and cut it to fit under the louvers. When you want to clean out the dirt that will get into the louvers you can remove the magnetic sheet, clean everything and put it back on. Joe
i just had my deck lid louvered,i put dp 90 epoxy and then black single stage on it,sent it back to brookville to put together,it wont last forever but it will look killer,wash it by hand and carry a piece of plastic to put over it if it rains
I recently sold a fellow some louvered strips which he epoxed to his glass duce deck lid, a ton of work but cheaper than the repo lids and you don't lose any body entegrity by cutting out the inner skin or bracing. there are some pics and a brief write up on the last page of www.hotrodlouvers.com
Hers is mine. I punched two panels out of 20 ga steel and used "JB weld" to hold them to the deck lid. A little" Bondo" and your finished.
Here is my fiberglass 32, steel panel bolted to fiberglass inner skin ,no leaks. steel hood has aluminum inner panel to keep water out of engine. ago
