I am looking for some input/advice and pictures for a swaybar set up on a leaf spring suspension. On my 49 Pontaic I have a TCI rear leaf kit, 4" lowering blocks and a ford 9". I would like to know where you install the brackets on both the frame and rear end housing for the swaybar...
Just look up 2nd gen camaro Z28's. They all have a rear sway bar and leaf springs. The sway bar is also probably the right width for your rearend since the camaro rear is a common swap into a car like yours.
Have you tried ChevyTalk, they have all the forms for Chevy cars/ trucks from day one and a wealth of info, Henry. http://www.chevytalk.org/fusionbb/showforum.php?fid/30/keyword/1949-1954_Chevys/ Also Canadian Form http://www.chevytalk.org/fusionbb/showforum.php?fid/128/keyword/canada/
try www.chassisengineeringinc.com they have alot of chassis products that could be used on your car.by the looks of them,the spring retainer plates are allready chassis eng. here is a link of some rear sway bars that may work. http://www.chassisengineeringinc.com/page25.html -danny
I used a kit from Chassis eng. similar to the 1040-R on my 54 Chevy w/ nova rear. I think your Pontiac would be very similar. Uses u bolts around the axle tube and the links go up to brackets you mount on the frame. Kinda ugly but it's very functional. You can't see it tho unless you crawl under there, so looks ain't that important.
