I am looking for some pics of tall shifter T buckets to decide what height to go with. If you could post some pics and said height it would be fanfuckingtastic! Should I go Lokar or Genie? Why? Thanks guys!
the tall shifter is supposed to be hook to a stick. I cut two transmissions to get my tall shifter In my chopped channeled and sectioned 54 GMC. I cut the first one at about 17 inches where it was still fairly fat on the taper, the second one was cut at the floor, then I ground the fat end then belt sanded to match the taper of the first one and welded the two together. I didn't want to cut a hole in the roof so bent it till I was comfortable shifting and it. ended up a couple inches short of the top of the windshield in your case Locar has a button. Gennie you could make it fit your Big Daddy cartoon dreams
