Hot Rods Look what showed up today.
Discussion in 'The Hokey Ass Message Board' started by keith27T, Aug 6, 2021.
      422.7 KB
      147.8 KB
    treb11, Deuces, Dave Mc and 32 others like this.
  2. alchemy
    alchemy
  3. Jalopy Joker
    Jalopy Joker
    so, have info/details to share?
    loudbang and Stogy like this.
  4. oldiron 440
    oldiron 440
    Sky Rocket
    Gotta love it....
    Deuces, loudbang and Stogy like this.
  5. Yah, just got this delivered today. 1962 oldsmobile super 88. First time I have bought a car, just by looking at pictures. It was a little over 700 miles away so I took a gamble., and had someone pick it up, and deliver. Pretty happy with it. The 394 fired up and I actually drove it in. Valves are a little ticky but, I think that's sort of the norm for these? Sounds not to bad. Almost 80,000 miles on speedo . Will be changing the oil pronto. I will keep posting progress. Just want to clean up and drive, for now. Will see where this goes.
  6. Big comfortable land yacht... what's not to like? LOL
    Deuces and loudbang like this.
  7. Fancy big old barge!
    I like it :cool:
  8. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Nice! and it's a 2 door.
    Run it with a quart of ATF or Marvel Mystery Oil for awhile prior to the oil change. It'll help clean things out and sometimes will free up sticky lifters. May have been awhile since the last oil change,
  9. Stogy
    Stogy
    When compared to a Hotrod Model A Coupe these analogies may be applicable...Longer Wider and Lower and great for skirts and lowering aka Mild Custom...Get the Lace out!!
  10. set me on fire
    set me on fire
    bet you throw some lucas oil treatment in and that tic goes away
    nice car good luck!
  11. oldiron 440
    oldiron 440
    I'd be concerned about sticking valves...
    Stogy and loudbang like this.
  12. swifty
    swifty
    You referring to the canoe or the Oldsmobile?
  13. alchemy
    alchemy
  14. ULTRA high compression!!
  15. BJR
    BJR
    Love those Oldsmoboats! :D
  16. AHotRod
    AHotRod
    Cool Olds !
    Ya gonna make a NHRA Jr. Stocker clone out of it?
    raven and loudbang like this.
  17. I’ve had a couple of ‘62 - ‘64 two door s like that. Always loved all that shiny trim and the factory interiors. Nice but!
  18. blowby
    blowby
    from Nicasio Ca
    Yeah baby!
    Needed for those Sky Rocket launches.
  19. Well a little progress yesterday. Changed the oil and added a little top end lubricant. Cleaned the air filter and put in a new filter. I don’t really here any stuck lifters. All I hear is a little loose rocker arms. I have adjusted chevy before but never an olds.
    Anyone no the procedures for adjusting them?
    I would like to know before I change the valve cover gaskets, as they look like there leaking a bit.
    Anyway going back today to start taking the front bumper off, and replace the parts that are banged up.The guy I got it from sent along replacement parts. Which is something I wasn’t expecting in the deal. Bonus!
  20. BJR
    BJR
    I think the Olds rockers are shaft mounted with no adjusters, so not able to adjust them.
  21. Yah Aguess you have to take the whole rocker arm assembly off and have the rockers ground.
    The motor has just under 74,000 miles. So going to leave-for now. And just replace the gaskets
    dirty old man and loudbang like this.
  22. Keith, you could try adj push rods to dial in the lash if the chatter drives you crazy.
  23. v8flat44
    v8flat44
    A friend had a 62 Super 88 soft top. As a Ford guy, I LOVED THAT CAR. Still do. Good on you! For it's size & weight, that thing would haul ___ Super cars, pun intended....
    keith27T, loudbang and Big mike 1968 like this.
  24. Roothawg
    Roothawg
    Don’t forget that 74,000 was wore out back in the day. It’s easy to forget since today’s cars regularly go 200k.
    Nice car. Enjoy.
    jaracer, ottoman, AHotRod and 2 others like this.
  25. Nice purchase, will be a great ride.
    If you get that "sky rocket in flight, can you expect some afternoon delight"? Sorry, song was in my head!
    Bird man, keith27T and loudbang like this.
  26. Thanks for this bit. I will check it out when I replace the gaskets.
    Started taking the front bumper off yesterday. As it is pretty banged up an rusted on the corners. Will be replacing the cast piece on the driver front fender as well. Nice that the owner included these parts. Aguess he was going to do it but never got around to actually putting them on.
    Wouldn’t be working on it for a few more days. But will add some pictures later
    The Magic Ratchet and loudbang like this.
  27. v8flat44
    v8flat44
    I think, not sure, that is Olds Hydraulic lifter normal noise. I do know GM made an additive for that. Might check with a GM dealer ????
    Stogy, loudbang and keith27T like this.
  28. Got the bumper off today sheesh
    Texas57, loudbang, Thor1 and 2 others like this.
