What's the application for the longer lines for the front of my hot rod? Stock 40s are too short. I remember hearing a later truck had longer lines. I did a search and found nothing. Thanks
You can go to napaonline.com and put in any vehicle and search for brake hose. This one is for '40 Ford: https://www.napaonline.com/en/p/UBK4900 You get the length and fitting sizes. Spend some time and you will find something that works. Or, go to Summit and get braided ( not the look you're after). This is for 1948 Ford pickup https://www.napaonline.com/en/searc...terchange=true&referer=herofitmentForm-newveh
Thanks I found the #'s. Not the application but it's a start. I forgot about the Google search option and found everything I needed with it. Cheers
