Technical Lifting for falcon
Discussion in 'Traditional Hot Rods' started by 63futurafalcon, Sep 6, 2021.
  1. 63futurafalcon
    63futurafalcon
    Does anyone know how I could lift a Ford falcon without a straight axle I would like to get one but I figured I could save money that could go to the engine or rear end so back to the question how could I raise a falcon front end without the straight axle
  2. seb fontana
    seb fontana
    from ct
    Put 1" spacers between lower spring mount and top A arm. Will get you about 2" with some degree of alignment.
  3. Budget36
    Budget36
    You might be better off getting new and taller springs for it, gotta figure after 60 years the originals has settled a bit;).
    You also (as mentioned above) need to look at alignment and how much adjustment you have to keep it correct. You don’t want that front end looking like the ass end of a Baja Bug.
  4. 63futurafalcon
    63futurafalcon
    Ok I’ll try that what do I just get like 64 stang springs ?
  5. Early Mustang springs will work fine.
    If you use V8 springs with a six banger it will be taller, but stiffer.
    Rubber ring spacers will raise it without it getting stiffer.
    Depends on what you want.
    VANDENPLAS and loudbang like this.
  6. Lloyd's paint & glass
    All Falcons were made to have a straight axle :D they are in my top 5 best looking cars with a straight axle ;) (top 3 actually)
    deathrowdave, Thor1 and squirrel like this.
  7. The way we did it back in the 60's was knuckle busters. HRP
    footbrake, VANDENPLAS and loudbang like this.
  8.
  9. 63futurafalcon
    63futurafalcon
    Thank you guys for the input I’ll probably use knuckles or v8 springs for now till I get the straight axle thank you!
  10. Latigo
    Latigo
  11. gimpyshotrods
    gimpyshotrods
    Yup. 1964-1/2-1966 springs are "too tall" for a unlifted Falcon. I have a set in my '60, with two coils cut off.
    You can also get taller isolators that go on top of the springs, for even more lift.
  12. Probably the cheapest easiest way A59C2931-F937-4B23-B0C3-F5DCEF2905E5.png
    warhorseracing likes this.
