Technical Least Restrictive Air Cleaner for 97'S
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 13, 2022.
  1. What is the least restrictive air filter / cleaner for Stromberg 97's ?
    I am running two 97's and the ones I have are causing rich conditions.
    I am using the 2" x 3-1/2 " paper units now. Thanks for any info. IMG_3572.JPG
  2. One of the members did a flow test on filters just a month ago or 2. Search for "flow test" might bring it to the top.
    clem likes this.
  3. manyolcars
    manyolcars
    My neighbor has a flow bench and uses it. He told me that the plenum I created was good. I laid a flat plate over my 3 deuces, with a hole for each carb, used 3x2 air filter (62 Ford 406??) and added another flat stainless steel plate as a top. Easy, effective. No photo
  4. choppedtudor
    choppedtudor
    upload_2022-11-13_12-1-42.jpeg Go TALL. More surface area = less restriction.
  5. Joe H
    Joe H
  6. FishFry
    FishFry
    K&N filters pretty much outflow everything else out there.
    Just make sure the housing doesn't become a bottleneck.
    Frank
    19Eddy30, deucemac and ct1932ford like this.
  7. What filters are those? Thanks
  8. 51504bat
    51504bat
    Don't know how they flow but I sure like the looks of these:
  9. choppedtudor
    choppedtudor
    I use filters for commercial air compressors.
  10. deucemac
    deucemac
    I have used K&N filters in everything I own since I started using them in my motorcycle racing days in the 70's. A fully dirty K&N will flow slightly less than a paper filter when new. I am currently running K&N filers on my F250, my wife's Mercury, my OT El Camino and my avatar hemi powered deuce roadster. K&N guarantees then 10 years or a million miles. Pricy, but good stuff with plenty of copy cats out there.
    ct1932ford, FishFry and loudbang like this.
  11. 19Eddy30
    19Eddy30
    from VA
    Size for size K&N to compare to others brands ,
    or just a mesh screen
    ct1932ford likes this.
  12. Thanks all! Looks like K&N
    FishFry likes this.
