Hot Rods Learning upholstery
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Jul 11, 2017.
  1. HomemadeHardtop57
    HomemadeHardtop57
  2. HomemadeHardtop57
    HomemadeHardtop57
  3. HomemadeHardtop57
    HomemadeHardtop57
    Got the seat back into the car for a test fit. My buddy Matt trying it on for size
    [​IMG][​IMG][​IMG]
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  4. HomemadeHardtop57
    HomemadeHardtop57
  5. Imwalkin
    Imwalkin
    from Tucson, Az
    Nice work, keep it coming.
  6. HomemadeHardtop57
    HomemadeHardtop57
    Started doing the seat bottom pieces that will get sewn together
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Okie Pete, reagen, brEad and 3 others like this.
  7. HomemadeHardtop57
    HomemadeHardtop57
    One of the things I'm learning while doing this interior stuff is that the panels look pretty horrible until they're stretched over the backing foam. Wrinkly!
    That's probably why you don't see too many in progress shots of interior work. .. you can see in the post above that I did how drastically different the pleated piece looks just by hanging.
    [​IMG][​IMG]
    3quarter32, Okie Pete, reagen and 7 others like this.
  8. brady1929
    brady1929
    Again, amazing!
  9. HomemadeHardtop57
    HomemadeHardtop57
    Taking a break from the model a seat to quickly recover a 1948 Barber chair for a friend of mine. He has a barbershop and this chair is in the corner.
    I got the seat bottom and footrest done and have a couple more small panels to go. These are small one inch top sewn pleats where you can see the seam exactly like the model a seat that I'm working on. It's neat to actually be making stuff for others. Having in!
  10. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Great choice in learning how to upholster. If I had known what I know now instead of going into the chassis business 35 years ago I would have apprenticed with a local upholster and would be doing that today. The really good creative shops in this area are far apart and many backed up for over a year.
    lothiandon1940 likes this.
  11. ballslammer
    ballslammer
    WOW! What an opportunity! ,,, I think I'd give my left nute to be given THAT opportunity ! thanks for sharing
  12. HomemadeHardtop57
    HomemadeHardtop57
  13. continentaljohn
    continentaljohn
    Looks great are you using a welting foot to do the cording
    HomemadeHardtop57 likes this.
  14. stanlow69
    stanlow69
    Try making the welt as you sew it on your boxing piece. It`s easier to hide the stitch line when sewing up your seat. I also like a longer stitch length per inch.
    6inarow and wheeler.t like this.
  15. wheeler.t
    wheeler.t
    I'm almost 10 years in and still learning (I am 28 and still learning, working for myself now is helping the learning curve)
    Keep up the good work. You're doing great!
    reagen, MIKE STEWART, rbrewer and 7 others like this.
  16. HomemadeHardtop57
    HomemadeHardtop57
    Yes!
  17. HomemadeHardtop57
    HomemadeHardtop57
    I tried that on a practice piece. I can do it on the straight sections but around the curves I have trouble. Need more practice..so for now I've been making the welt separately.
    6inarow likes this.
  18. HomemadeHardtop57,,,just a small hint,,Fiberflex is a much better fill
    for making weltimg.
    the hard plastic filler does not make corners as easily.I 've been using the fiberflex for over 50 trs.
    3quarter32 likes this.
  19. HomemadeHardtop57
    HomemadeHardtop57
    Thanks..I will try it!
  20. HomemadeHardtop57
    HomemadeHardtop57
    Finished up the barber's chair that I was working on from a friend. This was made in 1948
    [​IMG][​IMG][​IMG]
    3quarter32, reagen, 32SEDAN and 6 others like this.
  21. It is all looking very good! Not amateurish at all. Well done!
  22. Blue One
    Blue One
    from Alberta
    What size thread are you using and how many stitches per inch?
  23. 41woodie
    41woodie
    Anytime you can add to your skills and knowledge is like putting money in the bank. You obviously have talent in that direction, stay with it.
  24. HomemadeHardtop57
    HomemadeHardtop57
    Thread is 92lb bonded. I also have some 60lb. When I first started messing with this a few weeks back my stitches were very close..with the bobbin thread showing on top. I was just playing around and learning the machine. Now that I was taught how to dial the machine in the stiches are more aesthetically pleasing. On the Pfaff machine I'm using I have the stich setting on 5 or 5.5. 6 is the largest possible on the machine
  25. Great work, getting better and better. Question regarding the motor on your Pfaff. Are you using a clutch motor or an electronic servo motor?
    6inarow likes this.
  26. rjones35
    rjones35
    Wow! That's awesome, thanks for sharing. I knew it was a lot of work, but didn't know what all it actually took to do it!
  27. stanlow69
    stanlow69
    No matter what thread you use. It rots on the spool as it ages. If you can break it pulling it with it wrapped around your two hand, Throw the spool away. It will only get worse.
    reagen and Donuts & Peelouts like this.
  28. You are so lucky to have some one with his skills to lead you in the right direction.....I have always wanted to learn this trade...
  29. Wow, that`s some great work. I thought about taking an upholstery class. so I could do the seats in my 46 oldsmobile.
    6inarow likes this.
  30. HomemadeHardtop57
    HomemadeHardtop57
    Got the seat back finished today. Happy for my first one.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    reagen, 32SEDAN, Stogy and 1 other person like this.
