Projects Kaiser '49 - Ever seen custom?
Discussion in 'The Hokey Ass Message Board' started by nix, Nov 18, 2011.
  1. Squablow
    Squablow
    I don't know anyone who uses a pump in tank on a carbureted car, I don't think I understand why you would need to do that?
  2. nix
    nix
    from Italy
  3. nix
    nix
    from Italy
    ...because I can't put the electric fuel pump under the tank, it's mounted very low...
    Pumps inside the tank are also quieter, but for me this is not a problem
  4. Squablow
    Squablow
    Typically the pump is mounted just forward of the tank on the inside of the framerail.
  5. nix
    nix
    from Italy
    It's not the first time that I built a fuel line, my framerail is higher than the tank... I will find a solution..
  6. Moedog07
    Moedog07
    Any updates on your Kaiser 49 build?
  7. Bandit Billy
    Bandit Billy
    I have in-tank pumps on my 34 flathead roadster, my 41 hemi ford PU and my OT 442, all are carbureted. All of mine run Walbro pumps. They are high pressure pumps (58 GPH, 44 PSI) so they require a "return style" regulator like a Holley 12-887 or similar. In-tank pumps are quieter, run cooler and better looking (because you don't have to look at it) than any frame mounted unit.
    I think you find the Walbro is small enough to fit your tank. Summit sells them as does Tanks Inc (all their pumps are Walbro).
