Projects K-88 Dragster / 6 Cylinder
Discussion in 'The Hokey Ass Message Board' started by Countn'Carbs, Apr 30, 2019.
  1. Countn'Carbs
    Countn'Carbs
    from CO
    Got about 7' feet of DOM tubing, tapped the ends and drag link is done. Had to push it outside, step back and take a look.
    enigma57, Stogy, 1947knuck and 9 others like this.
  2. Countn'Carbs
    Countn'Carbs
    from CO
    Doctor says I need more magnesium.....I'm cool with that.
    enigma57, Stogy, 1947knuck and 6 others like this.
  3. Marty Strode
    Marty Strode
    Looks like we need to set up a match race with Mr. Ganahl !
  4. ENUF 41
    ENUF 41
    A Tip of the hat for your great looking work!!!
    Countn'Carbs and loudbang like this.
  5. Jethro
    Jethro
    There are times when you're building a project and you are working so close you can't see what you've done......stepping back , taking in the whole picture is really satisfying!......nice work! Keep it up!
  6. Countn'Carbs
    Countn'Carbs
    from CO
    Now That Would Be a Fun Day Marty!!!
    Thank you - I appreciate that.
    So True Jethro. An example is I've been wondering if I might need to rework the front spring mount to get the front of the car lower with that CAE axle but after seeing it outside it has the stance I was after.
    1947knuck, Stogy and loudbang like this.
  7. 41rodderz
    41rodderz
    from Oregon
    Good looking shop help there supervising.
    6-bangertim and Countn'Carbs like this.
  8. Countn'Carbs
    Countn'Carbs
    from CO
    It's been a long time coming but was able to pull the trigger on a Fabcraft Third Member. Nice piece and Dave was great to do business with - I highly recommend them.
    enigma57, Stogy, 1947knuck and 8 others like this.
  9. Countn'Carbs
    Countn'Carbs
    from CO
    Got the back of the seat knocked out. When the time comes the plan is to have the side panels wrap around the car to the back of the car to the same uprights.
    enigma57, Stogy, 1947knuck and 4 others like this.
  10. Countn'Carbs
    Countn'Carbs
    from CO
    After looking for 2 years for a gennie Chassis Research pedal, I gave up and Thank God for Dennis at O'Brien. He not only came through with a great piece but he's an Alliance Vendor to boot!!
    This is where it's finally going to end up. After building the bracket I've had it several places in the car and this is the most comfortable with ease of getting in/out of the car so that's where she'll go.
    TFoch, enigma57, Stogy and 6 others like this.
  11. Countn'Carbs
    Countn'Carbs
    from CO
    Starting to come together - bit by bit.
  12. Fabber McGee
    Fabber McGee
    Is that your tow car next to it?
  13. Countn'Carbs
    Countn'Carbs
    from CO
  14. rusty rocket
    rusty rocket
    Stogy, loudbang and Countn'Carbs like this.
  15. paintman27
    paintman27
    from new jersey
    I'm not so sure the drivers pair of nut sacks would agree with that statement
  16. Cliff Ramsdell
    Cliff Ramsdell
    Yep, I’m liking this project. Great job and I’m following along.
    Cliff Ramsdell
    48fordnut, loudbang and Countn'Carbs like this.
  17. jimmy six
    jimmy six
    Countn'..... Any reason you didn't come off the side of the block for mounts to the rails? I started out using the same front mount as you but moved out to the side many years ago. I was a cleaner look for me and I started drive a lot off the crank/damper area. I'm impressed by your craftsmanship. You to be congratulated on your work and perserverance.
    enigma57, Stogy and loudbang like this.
  18. Countn'Carbs
    Countn'Carbs
    from CO
    It is......Tow/Chase Vehicle
  19. Countn'Carbs
    Countn'Carbs
    from CO
    Great observation Jimmy Six - originally I was mocking up with a military block and was making templates to come off the side bosses on the military block to the rails. When the 12 Port came into the picture it is rebuilt and ready with a civilian block so I followed Bob Corbett's suggestion of just using a truck front mount and making a cross-member with a flat spot for the truck mount to bolt up from the bottom.
    The thought is with that design I can then shim at the front of the block if I need to and/or at the mid-plate for alignment of the coupler.
    You bring up a good point though about if I want to start driving stuff off the crank - I always appreciate your input and so glad you're following along.
    1947knuck, enigma57, Stogy and 2 others like this.
  20. Countn'Carbs
    Countn'Carbs
    from CO
  21. Countn'Carbs
    Countn'Carbs
    from CO
    As I mentioned Joe Umphenour's first dragster was the inspiration behind this build. Here is a rare shot of driver Mike Franckey about ready to unleash the 12 Port equipped TE-448.
    Another shot of the car....
    winduptoy, cactus1, enigma57 and 5 others like this.
  22. Countn'Carbs
    Countn'Carbs
    from CO
    Drew this up to have a buddy get a header flange widdled out.
    Here it is on the engine. I'm very happy with the way it turned out and now comes the fun part of figuring out what kind of pipe style...i.e. straight out, up and back, etc...
    winduptoy, cactus1, enigma57 and 6 others like this.
  23. Countn'Carbs
    Countn'Carbs
    from CO
    Some shots I've gathered over the years for when the time comes...
  24. Cliff Ramsdell
    Cliff Ramsdell
    Wow, nice choices.
    The straight ones are crazy.
    The zoomies are cool but I think more fitting under a funny car body because they have an unnecessary bend to them coming out of the port.
    I like the ones in picture 6, out and to the back. Clean, simple, functional.
    Great build, love the chassis, I owned an original one. The jimmy mill is cool stuff.
    Cliff Ramsdell
  25. shivasdad
    shivasdad
    from Texas
    I like the swoopy design in the last picture. Cool project.
  26. Roothawg
    Roothawg
    Just found this thread. This is spot on re-creation. Well done sir.
  27. jimmy six
    jimmy six
    You bring up a good point though about if I want to start driving stuff off the crank - I always appreciate your input and so glad you're following along.[/QUOTE]
    Bob is the man so I understand your point. My son and I are putting our old Bonneville/lakes 40 Chevrolet on the street. It had both side and saddle front mounts and they were rigid. We are using the original record setting civilian block and I made side mounts for stability. The rear will get 55-57 car bellhousing mounts and the 4-speed, a lower factory mount. The sides will sit on truck mud flap rubber above and below the cross mount.
    I asked him if he want one of my 12 ports and he said no.. He wants it like we raced it but a little calmer.:rolleyes: I'm glad I collected 50 years of GMC speed equipment parts....
  28. Countn'Carbs
    Countn'Carbs
    from CO
    Thanks Cliff. I would love to here about your Chassis Research car. What years did you have it, what engine, where did you run it, etc... Great Stuff for sure!!
    That's Al Teague's car - hard to beat that look for sure.
    Thanks I appreciate that - hope you continue to follow along.
    [/QUOTE]
    That's great stuff Jimmy Six and I for one am glad you collected a bunch of GMC speed parts. You don't by chance have an injection setup for a Fisher do ya?? I'm looking forward to seeing your coupe back on the street and I'd like to check that car out in person someday!!
    1947knuck, enigma57 and loudbang like this.
  29. 48fordnut
    48fordnut
    Headers on yellow car.
    6-bangertim and loudbang like this.
  30. jimmy six
    jimmy six
    Sent you a PM
