Hey' can somebody tell me how to lower the back of my 51 chevy wagon it has the orignal torque tube and leaf springs still in it Ijust wanna 1"-2" drop, will blocks work ? thanks Brian
Blocks will work fine, you have rear leaf springs, so you just need to remove your old u-bolts, put the blocks in between the rearend and the springs, then replace the old U-bolts with longer ones. Speedway sells them.
Squablow, thanks for the info I wasn't sure cause of the configuration of the bolt ontop of the leafspring thanks Brian
don't worry about speedway and their shitty service of processing orders. The did mine a day late for some reason. Head over to your local autozone, and pick up a set. I went with 3" in the back. I think it was 41$ all together. The parts are good quality, not what I expected. -Rick
