Job Rated Dodge truck: What poly engine?
Discussion in 'The Hokey Ass Message Board' started by Brad54, Oct 15, 2011.
  1. Brad54
    Brad54
    from Atl Ga
    Found a Job Rated Dodge with a poly-head engine in it today.
    It's got a one-piece windshield, if that's an indicator of the year.
    What engine displacement would this be?
    -Brad
  2. plmczy
    plmczy
    I helped my buddy pull one out of a 55-56? dodge truck the day hurricane irene hit pa. when he got it home and looked up the numbers he said it was a 241. hope this helps.
  3. Hadley
    Hadley
    from Indy
  4. 73RR
    73RR
    Look for the 'use code' stamped in the block.
    First question is whether it has a separate valley cover or if the intake manifold seals everything.
    A separate valley cover indicates it is a Hemi-based poly and the id will be found on the top front of the block, ahead of the valley cover. The other will indicate an A series engine (like a 318) and the id will be stamped on the front of the block just below the head gasket on the driver side.
    The Hemi-based poly id numbers are on my web site.
  5. George
    George
    TR Waters has posted pics of truck hemis & Polys with the use code there also.
  6. Brad54
    Brad54
    from Atl Ga
    I went back today and forgot to look for the code on the engine.
    It's NOT a 318, that much I know (separate valley pan under the 2bbl intake)
    The block doesn't have the extended bellhousing, if that helps further.
    Thanks,
    -Brad
