Technical ***January 2020 Banger Thread. Happy New Year!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 31, 2019.
  1. The37Kid
    The37Kid
    [​IMG] DSCF0766.JPG DSCF0765.JPG Radiator hose to protect the gear is traditional.:confused: Every lobe was ground on a grind stone, photos don't show that. Think they made a test profile and finished with a file in the old days. Bob
    Old Dawg, hotrodA and Jet96 like this.
  2. Could be
    Not all spoken for
    J
    Crazydaddyo likes this.
  3. Bob
    yes I have copper plate done before rough grind
    This makes carburizing of wear surfaces and the rest soft
    John
    Old Dawg likes this.
  4. PhredH
    PhredH
    My Model A flywheel currently has the V8 clutch, and at first glance it may need bit of attention.
    I have heard of a GM clutch being used with our Model A's.
    If this is a not uncommon modification, is there any advantage to that clutch over the V8 clutch?
    What clutch is used?
    Will my Model A flywheel that is modified for the V8 clutch need any additional machining other than properly located mounting holes?
    Does the Model A throw out bearing system still work with this mod?
    Is there a clutch disc that fits this clutch and the Ford input shaft or does the input shaft need to be replaced?
    Thanks in advance for any experienced input and any other things I may have not questioned.
    Peace, Phred
  5. mdimages
    mdimages
  6. jadz928
    jadz928
    from Michigan
    '29 Roadster w/Model B & Miller Schofield OHV - first startup since 1985.
    Shutter Speed, rwrj, Old Dawg and 4 others like this.
  7. ghalperin
    ghalperin
    Does anybody have any early Mallory instructions?
  8. V4F
    V4F
    from middle ca.
    do not know about gm clutch .
    is your flywheel already using v8 clutch ?
    yes on throw out brg
    I believe the ford clutch will work with stock trans
    hope this helps …………. steve
  9. I need recommendations on a seal set up for the front and rear of the oil pan for a Model B. This does not have any enhanced oiling. just looking for a better set up than the rope and cork set up.
  10. railcarmover
    railcarmover
    Fun time,running fuel lines,buffing headlights,fabbing stands.Gonna run 8000 lumen LED's,fella give me a pair of reflectors for H4 halogen..be a menace to safe motoring,blinding all those who approach me :)
  11. Fabber McGee
    Fabber McGee
    I bought a "C" head at the Turlock Swap Meet on Saturday. How much can I safely shave it?
  12. 97
    97
    I was always told that for what you increased the compression by it's not worth the effort! ...to plane a Model A head. I was always told 0.080 is as far as you can go without wrecking it...and that is from stock....AND if you do take 80 thou off and also clean the block you can get about 125 between the two of them, BUT you have to be careful you don't have pistons above the block surface. If so you will need a thick gasket which will just undo all your hard work!.
    http://www.fordgarage.com/pages/ABcylinderheadcomparison.htm
  13. ghalperin
    ghalperin
    It looks great.
    As far as the headlight mods, this is from: http://www.audettecollection.com/
    rwrj and Jet96 like this.
  14. ghalperin
    ghalperin
    I’m adjusting my crank babbitts. Should I use new ARP nuts or reuse the original nuts? I’m replacing the rod nuts with ARP. The cotter pins were not installed on the main cap nuts when I took it apart.
  15. Jalopy Joker
    Jalopy Joker
  16. BCCHOPIT
    BCCHOPIT
    Happy New year Bob!!!!
    The37Kid likes this.
  17. BCCHOPIT
    BCCHOPIT
    Not much Mr. Ford didn’t leave us much meat
    winduptoy, Old Dawg and Fabber McGee like this.
  18. railcarmover
    railcarmover
  19. railcarmover
    railcarmover
    The combustion chamber design is what screws you for raising compression.Shaving is a minimal increase
    Fabber McGee and Old Dawg like this.
  20. railcarmover
    railcarmover
    In my opinion the land the nut rides on is as important as the nut itself,I used hard washers and quality grade 8 nuts,instead of cranking the nut against the grey iron.
    Using cotter pins to hold torque is a waste,tension can degrade against the pin. A torque value is designed to place the fastener in tension,basically the assembly 'stretches' the bolt,locking the threads.I use blue locktite, anaerobic sealants like loctite provide a means of retaining the assembly without potential loss of tension as with a cotter pin.
  21. I can't disagree with the above statements, all true.
    One factor though is no one looks at the bolts themselves.
    I have seen some yielded past tension and would not hold any torque.
    My 0.02$, not to be an advertisement, but I have never had any of Dan McEachern's main bolts fail or yield.
    Not to mention they are sized properly, diameter.
    Personally, I like to use the ARP 12pt nuts wherever I can, expensive, yes, but very seldom have to replace.
    One trick from a well known builder here, on stock rods, the castle nuts have very little full thread length.
    This is a place where ARP 12pt nuts are your friend.
    John
    Jet96, Old Dawg and GuyW like this.
  22. "Mock it Up" before you do anything! That way you'll be able to know and decide what you want to do! "Been there, done that"!
  23. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Even though I sold my banger coupe, still love to come here and dream, Another banger but hotrod banger tudor sedan is in the future I think....
    winduptoy likes this.
  24. Fabber McGee
    Fabber McGee
    Okay, thanks guys. I have a B engine in a 31 closed cab pickup wearing a cracked A head. Just planned on replacing the busted one with this one and thought it would be good to take off about .125 if I could. I guess we'll just cut it enough to clean it and slap it on there.
  25. lake_harley
    lake_harley
    Here's a link to a thread on fordbarn that might at least give some information and it seems to be quite a well informed post. Scroll down to post #11 by Purdy Swoft. https://www.fordbarn.com/forum/showthread.php?t=48414&showall=1 I believe it's all based on a stock Model A head, but it might give some guidance on your "C" head, and I'd think it would be of interest to the stock Model A head crowd that might want a bit more compression "on the cheap".
    Lynn
    Fabber McGee likes this.
  26. railcarmover
    railcarmover
    Youll catch 4.8 to 1 or so,they start at 4.6..but hell yeah,run that sucker till one falls in your lap
  27. ghalperin
    ghalperin
    Do you have a part number for those ARP main bolt nuts?
  28. ghalperin
    ghalperin
  29. That would be my choice, the SS ones are too expensive.
    Also, check pricing at Jegs and Summit racing, also Red's headers, Victor I think has them.
    http://www.reds-headers.com/html/contact_us.html
