Technical ISO a Weber carb genius.
Discussion in 'The Hokey Ass Message Board' started by Nitro450exp, Aug 2, 2020.
  1. Nitro450exp
    Nitro450exp
    Picked this up, want to use it on a 327 to 350 SBC 8:1, 4-71 at about 8 psi. The idle circuits and main jet circuits are missing ( no biggie I figured I would need to rejet anyhow)
    Looking for Weber guru who can reccomend main jet sizes, emulsion tube sizes, idle jet sizes, accelerator pump jet sizes float seat etc.
    I will probably get a jet kit, but it only comes with mains and idle jets in 8 incremental sizes, so I need to be close on the other sizes before trying to dial in the final jetting.
    Carbs are Italian made Weber 40DCOE32 models.
    Can they work on a blown mild SBC or do I need to step up to 45mm or 50's ?
    THANKS
  2. Nitro450exp
    Nitro450exp
    This is what was standard in the 40DCOE
    But probably for an 1800cc to 2000cc 4 cyl Alfa.
  3. gimpyshotrods
    gimpyshotrods
    That's about 1/2, or less, of what you wound need for your application.
    I have fairly routinely installed two 40s, and eve 48s on air-cooled VWs.
    This is a 348:
    Not one of mine, but it shows how many can be used.
  4. gimpyshotrods
    gimpyshotrods
    Dual 40s are customarily found on 1.6l to 2.0l 4-cylinder engines.
    A 289 Cobra had four 48s, and no blower.
    loudbang, Hnstray and TrailerTrashToo like this.
  5. gimpyshotrods
    gimpyshotrods
    The biggest benefit of the Weber (and similar) carburetors of this type is their IR (individual runner) design. Each barrel services a single runner, to a single cylinder, for maximum efficiency.
    Once you dump all of that into a supercharger, that benefit is void. At that point, you are just in in for the look.
  6. Inglese's website shows a couple of setups with 2 weber carbs on top of a blower (4-71), so it seems like it's doable. There's no information beyond the images, but an uneducated guess is that it goes on top a pretty small engine with low boost.
    They also have an intake for 4 carbs on top of a blower.
    I agree with gimpy that it's just for looks... but it's a pretty cool look (well... the blue finish, not so much). :)
  7. Phil1934
    Phil1934
    B&M offered 2 40s on their 144 as there is a big demand difference between plenum and individual runner
  8. nrgwizard
    nrgwizard
    from Minn. uSA
    Gimpy is right, & the IR effect is destroyed if these are used on a plenum also.
    Marcus...
  9. Nitro450exp
    Nitro450exp
    1 tube feeding 1 runner, but with blower and single plane I essentially have 4 tubes feeding 1 runner at a time.
    I actually think a 45 or 48 is too big, that is why they chose 40's
  10. gimpyshotrods
    gimpyshotrods
    That's part of a BDS setup that used FOUR 40s.
    Two might be fine, for a 4-71, on a small flathead.
