Is it ok to mount split bones upside down..
Discussion in 'The Hokey Ass Message Board' started by JasonB, Mar 3, 2008.
  1. JasonB
    JasonB
    I was wondering it its ok to mount them upside down with the welds facing up. I want to do this for steering arm clearance.
    Thanks,
    Jason
  2. SinisterCustom
    SinisterCustom
    Sure you can.....but your going to have ta pie cut the 'bones to get yer caster back....
  3. alchemy
    alchemy
    Will probably throw your caster way off.
    What year do you have? A thru 34 hang low, while 35 and up hang high.
  4. Kramer
    Kramer
    I hope you can because I did. And I did the pie cut to correct my caster. Actually don't have the caster set just yet, so I haven't welded them up yet.
  5. Unkl Ian
    Unkl Ian
    You can also relocated the other end,
    where it attaches to the frame,to get the Caster where it should be.
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    Depending on which year wishbone and how much caster you want you could very well end up with some low mounting points without pie cutting. Might even be below scrub-line or underneath driving surface in some instances.
