Hot Rods Is it not getting enough air?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 10, 2018.
  1. The K&N filter was marginally better but it still restricts air flow,I took the filter out when I left the cruse in last night and the engine ran considerably better.
    I'll try Ricks idea until I order the frog mouth and use the fine mesh filter. HRP
    Petejoe and osage orange like this.
  2. dirty old man
    dirty old man
    Did you ever check for clearance between the bonnet and the base of filter element?
    HOTRODPRIMER likes this.
  3. Yes I did Dave,there is no obstruction with the element and base. HRP
  4. ...........my 8N and Cabroilet run a washable unit like I run on my triple Kaw..... 20180415_141014.jpg 20180415_141150.jpg
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    I received five of the round type just today to replace all of my carbs filters.
    I like them so far.
    The mesh material is a rather cheap material but can be easily replaced with better material since the plastic ring pulls out to remove them.
    Stogy likes this.
  6. Dan Timberlake
    Dan Timberlake
    Do those carbs' bowl vents go to atmosphere, or to the airhorn, inside the filter ?
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Dan, inside of the filter at the air horn. If I am following you correctly.
  8. bchctybob
    bchctybob
    The louvered air cleaner covers can be improved slightly by using a flat blade screwdriver and opening up each louver as much as possible. I noticed one time that the louvers were not uniformly open, some were almost closed completely so I opened them all as much as possible. It had to help.
  9. slowmotion
    slowmotion
    Maybe a longer stud & run 'em double-stacked. More inlet area...
    wandi harry likes this.
  10. Jkmar73
    Jkmar73
    from Tulare, CA
    Maybe some thing like this. For a 48 IDA. Says it will filter down to .009”.
    Jake
  11. I am going to throw this out there because I can and not to slight anyone.
    Foam filters make your carbs fire bombs as a rule. A simple backfire which happens more often than we would like to admit and your turnin and burnin.
    I may think of taking a gauze filter ( like a K&N) apart and modifying it to work long before I would run a foam filter. Of course this is me personally.
    Stogy likes this.
  12. Tim
    Tim
    from KCMO
    Source for that?
    Also did the OP ever find something that worked for him?
  13. Blue One
    Blue One
    from Alberta
    Danny sold the coupe.
  14. sunbeam
    sunbeam
  15. Jkmar73
    Jkmar73
    from Tulare, CA
    Piercemanifolds.com I am going to get some for a pair of Weber 48 IDAs I am running on an off topic car.
