Intake ID
Discussion in 'The Hokey Ass Message Board' started by Scrounger, Mar 5, 2012.
  1. Scrounger
    Scrounger
    I need a little help id-ing a intake manifold I picked up today.I "think" its a fuel injection set up from a 57ish Bonneville or Star chief.The only casting # I could find is a ECU9425C.I was able to get the manifolds,fuel pump,TB,and heads also if any #'s are needed off those parts.
  2. squirrel
    ford Y block. it's a carburator
    edit: or not...
  3. Scrounger
    Scrounger
    Thank you sir,thats all I needed to find the right info.Its a Y block intake w a Holley 4100 "tea pot" carb.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's actually from a Lincoln V8 of the '52-'57 style.
  5. squirrel
    I was thinking it was a Ford product, but not a 292 type Y block. The thermostat goes the wrong way. Thanks for the clarification.
  6. 30over200
    30over200
    Ports are wrong for a y block but yep lincon y block port are on top of each other. Hard to think that holley was the predeseser of 4150/4160
  7. Bruce Lancaster
    Bruce Lancaster
    Perfectly normal Holley four barrel, once you get used to the idea that they turned it inside out!
