Hot Rods Installing a 200-4r in a 1935-40 Ford chassis with split bones
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jun 8, 2015.
  1. Roothawg
    Roothawg
    Anyone done it? I am planning on tackling it as soon as I get back to OK this weekend. Just wondering what you did with the attaching point for the wishbones? I know you end up trimming the center section heavily. I know a 4 bar would eliminate the problem, but I was hoping to keep the bones if possible.
    Thanks,
    Root
    Model T1 likes this.
  2. 42merc
    42merc
  3. derpr
    derpr
    I'm not sure but isn't that transmission the same size as a turbo 350
  4. okiedokie
    okiedokie
    from Ok
    Sure like to see some other comments on this. I could never find any.
  5. Mine has a TH350 and I used the standard split kit that replaces the bottom of the crossmember.
  6. Model T1
    Model T1
    I'm waiting for answers. My 39 has a powerglide that hasn't moved since 79. A 2004R seems right.
  7. zman
    zman
    from Garner, NC
    Pretty much, though the crossmember is different as it a little bit back from where the TH350 one would be.
  8. 34toddster
    34toddster
    from Missouri
    I'm almost sure this trans has the trans mount the same place as a 400 Turbo and a bit more of a problem installing in the given area to work with, but I too will wait for the experts to chime in.
  9. zman
    zman
    from Garner, NC
  10. Roothawg
    Roothawg
    It requires more cutting to clearance the pan. The pan is massive on a 200. On a standard plate kit, like the TH 350 Chassis Engineering, you lose the tie rod mounts for the wishbones.
  11. The 39 guy
    The 39 guy
  12. Roothawg
    Roothawg
    Yep I have been looking at that some. Helps me with my visual.
  13. The 39 guy
    The 39 guy
    I have been doing some reading on this in the past and today for a refresher. I make no claim to know much on this subject but here is what I gleaned from my searches. Bottom line is this, don't split them unless you have to ( you have to). If you do, don't change the caster much. The splitting of the wishbones puts more stress on the axle but if the car is lowered the stress on the axle is minimized because the axle travels less than the stock height configuration. If you build a good strong bracket to hold the new rod ends you should be fine.
  14. Jalopy Joker
    Jalopy Joker
    check with weedetrstreetrod.com . run by Weedburner 40 here - they do top notch chassis work, and sell parts. likely help you figure it out.
  15. okiedokie
    okiedokie
    from Ok
    I made sure to place my new brackets at the same level as the CE bungs were to make sure caster remained the same.
  16. Last post was completely no help what so ever, it was the end of my lunchtime and I couldn't find the link.
    I found this for a 700r4 into a '35/'36 frame (they have others for '37-'40), it ties into the stock frame. Maybe box the section above the wishbone mount or even tie that section into the outer frame rail next to it. Then use weld in split wishbone mounts.......I know it sounds hokey but you can make it look good.
    http://www.morfabcustoms.com/catalog/Catalog2005.html
  17. okiedokie
    okiedokie
    from Ok
    The Morfab deal is a good one, but not for split bones unless you want to go to frame rails. Now with a 4 bar or Mustang II it would work, but it is made for using a 700R4.
  18. Roothawg
    Roothawg
    OldTimer, that is exactly why I decided not to use the 700. It looked way more invasive than I would have liked. I think I may have an idea, but I am traveling with work and won't be back til Fridayish. I'll take a look at it then.
  19. True, was posting pics for ideas. The 200 pan is longer and the mount is further back then the 350. I still think after the center mods you have enough x member to run the split tabs for the bones under them.
  20. Roothawg
    Roothawg
    I sure hope so. We will find out this weekend.
  21. okiedokie
    okiedokie
    from Ok
    Looking forward to weekend when Roothawg shows me a better way, and I say "doggonit", or something like that.
  22. Roothawg
    Roothawg
    DON'T GET YOUR HOPES UP..
  23. Model T1
    Model T1
    I know the tranny mount on a 2004R is back a little farther than a Powerglide and 350. I swapped to a 2004R in my 55 Chevy from a powerglide.
    That's my concern on swapping a 2004R into a 39-40 Ford. The X-member may not allow for the extra width and tranny mount a few inches back.
    Still waiting. I'd rather say yippy than dog gone it.
  24. Roothawg
    Roothawg
    Well, the tranny guy is still waiting on my clutches, so it won't be til next weekend possibly.
  25. nobux
    nobux
    The trans mount location on a 2004R is roughly the same as a TH400, the overall length is the same as a PG or TH350. I replaced the 400 in my 66 Caprice with a 2004R. It bolted to the stock crossmember, and I used a Powerglide driveshaft.
  26. okiedokie
    okiedokie
    from Ok
    No progress on the trans.
  27. tj
    tj
    Just swapped a 2004R for a 350 on a 40 Ford with a Nova clip. It takes a lot of trimming on the lower flange of the X member and fabricating a mounting plate similar to what Chassis Engineering manufacturers for the rear trans mount. Ended up placing additional stiffening plates on the outsides of the X member where the trimming was done. All I can say is it's very tight and with the bones it may be more difficult. Problem is that the 200 is so wide at the tail section.
  28. Roothawg
    Roothawg
    The tranny guy called and I pick it up sat morning. I'm on vacation fr the next 2 weeks, so the thrash is on!
  29. Good thread I have 200 4R for my 36. I also plan on a chassis eng axle and split wishbones
  30. 40 Coupe Since 69
    40 Coupe Since 69
    I'm reading this, on the edge of my seat, actually in the garage laying on the floor with a 2004R on my chest trying to figure out how to get it in, and it just stops :-(
    So, what happened?
    Mike
    Johnboy34 likes this.
