Technical In a pickle (I think) with valve spings and hyd flat tappet cam
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 28, 2020.
  1. Budget36
    Budget36
    So helping a buddy out here, let me give you the background:
    He bought Ebay ProComp heads.
    I had a post about it...so we then clearanced them for the pushrods.
    We used some two-stroke mix to see if the valves sealed...1/2 didn't...so off to the shop he went for a valve job.
    I went back and port matched the intake gaskets for him...that's when I really looked at the heads
    The springs are double springs, quick search on them says could be for roller cam or flat tappet...he doesn't know what he has.
    I said heck, best way out is a new set of springs....off to Summit to look at stuff...
    So, he has 1.5 (there abouts) diameter springs and what appears to be 1.75 installed height.
    I'm going to measure his cam lift on Saturday, I think with the 1.5 RR's he has should be close to .500
    Begs the question, I can find any flat tapper springs at his installed hieght to lower the seat and open pressure...everything I find is more for a roller cam.
    So...I wonder about a few options...
    Pulling the inner spring and breaking in the cam...then putting it back together.
    Thoughts?
    Are there offset keepers I can use to lower the seat pressure and make the springs a better fit?
    Last option I see, is having buy new standard length valves and pushrods and springs and have the valves cut again.
    I don't know his spring specs, but say I get 1.75 installed height springs from Comp/etc. with 130lbs seat pressure..use an offset keeper, can I tune the springs correctly?
    Engine is a .030 327, without pulling it down (not HAMB friendly in the front of the engine) to pull the cam, I've nothing to go by yet.
    I don't want him to eat the cam after it's broke in.
    Thanks
  2. gary terhaar
    gary terhaar
    from oakdale ny
    Flat tappet solid needs 135-140 on the seat and try to stay under 400 over the nose.
    Most of the heads as you discribed use pressures in this range for a hydrolic roller witch is fine.
    A flat tappet hydrolic should be 110-125 on the seat and up to 300 over the nose depending on profile.
    Pac strings has a hot rods series of spring to fit your needs as well as your pressures.
    I had more than my share of spring failures ,I use psi or pac and never think twice
  3. Budget36
    Budget36
    Good info,
    He has flat tappet hydrualic.
    I'll do a search for Pac springs and see what pops.
    Thanks
  4. gary terhaar
    gary terhaar
    from oakdale ny
    If you don't see what you need on line ,call tec,they recommended springs they don't list on line more than once for me.so call them,there pretty sharp there.
    Just a side note,springs are like lifters,there is only 2-4 places making them,everyone else reboxes
    With there name. Pac and psi make there own.second to none with testing and quality control.
    Budget36 likes this.
  5. Budget36
    Budget36
    Thanks Gary,
    I found Pac, but they are one the East coast (NC) so emailed them what I was looking for. Probably get a reply tomorrow.
    Thanks again!
  6. Budget36
    Budget36
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Where did the cam come from? What are you doing for lifters and pushrods?
  8. X-cpe
    X-cpe
    First step before making any changes.
  9. RmK57
    RmK57
    Take a couple off and get them checked at installed height and at full lift. 130- 400 seems overkill for a .500 lift sft cam to me.
    ekimneirbo likes this.
  10. Budget36
    Budget36
    Well, seems he had the motor built about 6-8 years ago.
    He doesn't have paperwork on it, with the heads off I see the block was mildly skimmed, not zero-decked, he has flat top with 2 valve relief pistons. Hence I don't think he has a peanut cam in it, I'll get the lift this Saturday.
    All I can tell 100% at this time the cam is a hydraulic flat tappet, he has "procomp" 1.5 roller rockers, he has +.100 PR's (Comp hardened) to get the contact pattern correct.
    Yes, we pulled the topend off to work on the heads for PR clearance, etc. The front of the engine is Streetrod with the pulley/pump/etc setup, inorder to get the cam out.
    I'd rather error on the side of caution and run a proper hyd flat tappet spring and and let him have vlave float, than eat the cam with too much pressure. Yes, I know there is a downside to valve float,,,but we'd find out quickly enough if that was an issue.
  11. Budget36
    Budget36
    That's my thinking as well, I wasn't able to find any 1.75 intsalled hight springs that looked suitable for the 110-120 seat pressure.
  12. Budget36
    Budget36
    Thing is, shop rate was quoted to him at 90 bucks to check a spring. Summit has a pressure tester for 80 bucks...a new set of springs I was thinking (at the time) was a 100 bucks.
    Math says unless his springs are a good match after having the shop test them or buying the tool, it's break even..vs buying the proper set of springs now.
  13. Ted Chandler
    Ted Chandler
    At the risk of insulting anyone, is it actually an inner spring or is it a flat wire damper? I have seen a lot of confusion on this issue over the years. If you can't get a spec from the manufacturer, you will need to get them checked just to be safe.
    loudbang and X-cpe like this.
  14. Budget36
    Budget36
    Definitely an inner spring, no rotators at all.
    Ted Chandler likes this.
  15. sunbeam
    sunbeam
    For compareson 350hp 327 specs 1.66 installed height and 175 lb @ 1.26 From what I have read buy the heads bare and buy quality valves, springs and retainers. Things that steal HP to much spring pressure and to oil pump.
  16. RichFox
    RichFox
    To answer one of your questions. Yes they do sell .050 up and down offset keepers. Maybe other offsets also but I have used ,050.
  17. Budget36
    Budget36
    Thanks Rich, maybe I'll just get one of those seat pressure things and play with it. Worst case is I have a tool left in the box when I'm gone. ;)
    I'll do some googling, but are offest keeper used to spring pressure or lift issues, or both? I've no experience.
  18. seb fontana
    seb fontana
    from ct
    bathroom scale and a drill press vs $80.
    sunbeam likes this.
  19. Budget36
    Budget36
    Heck, I don't even have a bathroom scale...tossed it years ago...them effers are depressing;)
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Have the friend pay half and you pay the other half to buy a $80 tester that you can use in a vice. You do the testing for him and you keep the tool when you are done.
    joe hot rod 32 and Budget36 like this.
  21. RmK57
    RmK57
  22. Budget36
    Budget36
  23. RmK57
    RmK57
  24. Budget36
    Budget36
    Good stuff there, I didn't consider going to a smaller diameter spring...once I verify his installed height and get ba look at the pockets, seems he will have more options.
    I really wanted to spend his $$ tho...tried to talk him in to pulling things down for a roller cam...he was hip to it, till he saw the cost;)
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    OK, let him buy new springs and you keep his old ones he can't use. Later on, find someone who can test them or get your own tester and maybe have some decent springs for a future project with a roller............
  26. Ericnova72
    Ericnova72
    from Michigan
    You can get a smaller diameter 1.250" springs, retainers, and locks package quite reasonable at Competition Products that will have the spring pressures you need.
    Only thing you need to check is the diameter of the step on the spring locator, to make sure it will fit inside the spring. If not, you'd have to order a new set of spring seat locators too.
    https://www.competitionproducts.com...ckage-1250-Dia/productinfo/VSA3/#.XtLRdzOSm70
    or
    https://www.competitionproducts.com...Spring-Package/productinfo/VSA4/#.XtLU0TOSm70
    Or you could measure the OD if the outer step that the spring locates in on the spring retainer for the current springs....if it is less than 1.080" there is a 1.437" diameter single spring Howards sells that would have the pressures you need.
    https://www.competitionproducts.com...0-235-1100/productinfo/HRC98411/#.XtLSvTOSm70
    And an 1.435" dual spring with the right pressures, if the retainer will fit a 1.055" inner diameter:
    https://www.competitionproducts.com...0-320-1180/productinfo/HRC98436/#.XtLTzTOSm70
    Truckdoctor Andy and Budget36 like this.
  27. Budget36
    Budget36
    Tomoorrow I'll know a lot more info to start with.
    Thanks all!
