I'm Doc, and I can relieve that pressure.
Discussion in 'The Hokey Ass Message Board' started by mark 55, Jun 30, 2009.
  1. mark 55
    mark 55
    For those of you that know him, Doc knows how to save a life, but if he had to post pictures to do it, we'd all be dead, So, I, who am only slightly better at this than a chimp, have agreed to post his solution to a little problem he ran into a while back. And now, in his own words;
    I'd been wanting to put a PM7 intake on the 31 Speed Special sedan for about a year now. Dick Spadaro took the one off his car, and I was able to pick it up (thanks Dick). I scored a couple of Stromberg 97's from Riley Automotive and I was ready to do the swap, but when I did the mockup, I ran into a little snag. The Thickstun does not have provision for an oil tube fill/breather. One solution is to run the breather at the fuel pump stand, but this would not work due to no clearance at the firewall. I had seen a post on the HAMB showing a flattie with a breather on the oil pan, so I figured that would solve my problem. I mounted a 45 degree Moon breather on the passenger side of the pan and it turned out pretty cool. Here's some shots to see how it turned out. Hopefully this will be useful to anyone who runs into the same problem. Enjoy! Doc.
      450.7 KB
      319.5 KB
      470.7 KB
      389.8 KB
      343 KB
      501.9 KB
      454.6 KB
      483.1 KB
      515.1 KB
  2. manyolcars
    manyolcars
    I saw that car on Youree Drive...on a trailer.
  3. Chaz
    Chaz
    Geez Doc, Do you own anything that isn't beautiful? Love that color.
  4. Hackerbilt
    Hackerbilt
    Hey...cool little A!
    Isn't it great how we can pick up tricks from a 60 year old photo?
    Theres always something to learn and it doesn't have to be something new!
  5. Casey
    Casey
    Good guy and neat car.
  6. Darby
    Darby
    So, when you get blowby on a decell, is it going to push oily vapor out onto those pretty headers?
    Pretty car, though.
  7. low budget
    low budget
    from Central Ky
    Nice ride! I also love the 55 in your avatar.
  8. KEITHMAN
    KEITHMAN
    Man-O-Man!!! Check the finish on that oil pan. SHINEY!!! You can see yourself. Cool idea for the breather. Only the one breather? Schweet Hot Rod! Nice work!
  9. flatoz
    flatoz
    looks good,
    but you do know that you can use the early fuel pump stand with the breather ontop so you can run an early intake on an 8BA, can even still run the mechanical fuel pump by just measuring the fuel pump push rod length and adjusting accordingly.
    I've always run the early intakes on the late motors as I think their cleaner in looks.
  10. Very nice Flatty! Looks good in black!
  11. Doc.
    Doc.
    I'm running that setup on my blown flattie, but it won't work on the '31. There is not enought room at the firewall. I really tried that solution but it was a no go. Instead of cutting a hole for the baffle, I drilled a series of 1/8 inch holes. It still breathes good and I think it will help to baffle the oil better than a big hole. So far it hasn't leaked a drop, even with hard brakeing. Oh yeah, and I trailer my cars all the time. Mark, you're out of the will for posting that pic of me. You know I'm in the witness protection program.
    Doc.
  12. DRUGASM
    DRUGASM
  13. bobbleed
    bobbleed
    from Awesome
    Cool...... that intake looks great!
  14. 29 sedanman
    29 sedanman
    from Indy
    That looks great Doc. I love everything about that ride!
  15. dickster27
    dickster27
    from Texas
    Doc nows that Tracy, he just built it to taunt you.
  16. Danimal
    Danimal
    1. A-D Truckers
    Schwing!!! Double Schwing!!
