idiot question - how remove chevy 283 bellcrank
Discussion in 'The Hokey Ass Message Board' started by neverwinter, Jun 20, 2012.
  1. neverwinter
    neverwinter
    installing headers and need to remove the clutch linkage. i got everything out but the bellcrank. this is on a 63 chevy c10 with 283 4 speed on the floor. the bell has a nut on the frame side that i got off but i cant get the end off the engine side. any thoughts?
  2. robertrj
    robertrj
    The frame side is slotted. Once you loosen the nut that side of the bellcrank should pry up.
  3. MATACONCEPTS
    MATACONCEPTS
    its a ball head bolt on the side of the block the bellcrank slides out away from the block. A 5/8"Open end wrench to unscrew. You might have hardend grease holding it.
  4. neverwinter
    neverwinter
    yeah i got the frame side no prob. i just dont want to break anything else - already snapped the dipstick tube doh. 9ill see about a wrench on the block side. thanks all.
  5. neverwinter
    neverwinter
    argh i cant get this damn thing. i may have mis-typed. what i need to get out is the round piece that has the 2 connecting arms for the clutch linkage. i can lift the frame end of the pieceup and out but i cannot slide that tube piece over enough to get it out. tried lightly tapping with a hammer, nada. do i need to hit it enough back towards the firewall side in order to slide it out so i can get the header in? what a pain in the a$$. i dont want to just bash things. i cannot get a wrench on the 5/8 side because that housing is in the way. does this make any sense at all lol?
  6. squirrel
    scrape all the grease off it, look for the clip....
    edit: I think the clip is on the frame end. You should be able to pull it off the engine end...damn it's been a long time since I took one of those apart.
  7. neverwinter
    neverwinter
  8. bustingear
    bustingear
  9. neverwinter
    neverwinter
    tried the hammer - now the whole thing is jammed. i give up for now.
  10. neverwinter
    neverwinter
    ok well i got it out and now the damn header STILL doesnt fit. awesome. time to call summitt
  11. DD COOPMAN
    DD COOPMAN
    Try removing the NUT from #7. Try tapping #7 deeper INTO the tube until the threaded-end of #7 is just INBOARD of the bracket/hole that it normally sits in. Once #7's threads are inboard of the frame bracket, lift the outboard end of tube just enough that you can slide tube assembly OUTBOARD, off of #8 ball. DD
