Technical ID Small Block Ford Lake Headers
Discussion in 'The Hokey Ass Message Board' started by bustingear, Nov 10, 2021.
  1. bustingear
    bustingear
    I usually work with Chevy and not so much on Ford but I do need some help in the ID of these lake headers. I do know they are small block and the outer most bolt holes on the exhaust flange measures 15 1/8" on center. Not sure if Y-Block, Windsor, Cleveland or what. I can provide any other measurements as needed. There is a picture of the header flange any help appreciated.
  2. squirrel
    Windsor, since the cleveland has the bolt holes offset, not in line. And Y blocks have the center two ports next to each other.
    you can go to a parts store and get a header gasket and see if it's right
    dana barlow likes this.
  3. bustingear
    bustingear
    Thanks!...looked the various gaskets on internet and you are right, Should have done that before but did not think of it.
  4. JimSibley
    JimSibley
    So, if they fit a windsor, dont they also fit a 289 and a 302?
  5. squirrel
    The 289 and 302 are Windsor engines. Although the Boss 302 isn't a Windsor.
  6. Deuces
    Deuces
    Those headers would be perfect for a small block with GT-40 heads.....
